SA324 Add a Backhoe Later?
/ SA324 Add a Backhoe Later? #1
MurilloGuy
None
Anyone know if you can add a backhoe later if you don't buy it right from the dealer at the start?
/ SA324 Add a Backhoe Later? #2
Having had one, my opinion is small tractor backhoe's are an over priced joke. Save your money, rent a full sized one for the occasional needs.
/ SA324 Add a Backhoe Later? #3
I think it depends on your expectations. I have a continual need to clear ditches. The scraper blade won't work and the FEL won't either. I'll be using my backhoe on a monthly basis. I also plan to clear out some trees for a garage in the coming months. Would a bigger unit do it quicker? Yup. But I already have this backhoe so I'll take a few more days and do it with what I have. I'm sure anyone used to using a large backhoe would get frustrated with the limitations of a smaller unit.
/ SA324 Add a Backhoe Later? #4
Depends on the definition of "small".
I have a 48 HP Kubota L48 TLB with an 11' advertised dig depth.
I don't know if it is considered "small", but it is certainly not a full size machine.
It is only for my personal use.
I do not use it often, but I love having it readily available, when I need it.
I do agree, that the hoes under 9' dig depth are relatively weak, and probably not cost effective.
/ SA324 Add a Backhoe Later? #5
Again, depends on your expectations and plans for use. If you buy it planning to dig deep, you'll be disappointed. Realistic expectations will go a long way on being happy with what you got.
2023 Bobcat T76 (A64126)
2023 Bobcat T76...
John Deere 5055E (A64126)
John Deere 5055E...
2010 International 4300 Truck Altec DM47TR Insulated Material Handling Digger Derrick Truck (A64194)
2010 International...
Bobcat Pallet Forks (A64127)
Bobcat Pallet...
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A65563)
IMPORTANT PLEASE...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A61567)
Pallet of...
