YM135D Air Filter Housing.
/ YM135D Air Filter Housing. #1
Rcpilot82
Member
Yanmar YM135D
Hello,
I have recently acquired my grandfathers Yanmar YM135D. When he had it he kept it so clean you almost eat off it. He has been gone for many years now and it has been through a rough life since then falling into disrepair and rusting. I have been spending Many hours repairing and repainting it to make it look like it did when my grandfather was alive.
That being said, I have hit a snag and the internet, Ebay, and local stores are of no help so far. The air cleaner housing is beyond repair between rust and damage. I was able to salvage the pre-cleaner and the bottom cap though. If anyone knows where I can find another housing whether it is used, lightly damaged, or at least repairable I would be appreciative. I have not found any cross reference for this air cleaner yet either but it seems to be common on a lot of Yanmar models.
Here are a few pics of the rebuild so far. I am looking for part #2 on the diagram.
Thanks for any help!
Yes I did. They said they don't have any. I got a bunch of my parts from them though.
/ YM135D Air Filter Housing. #4
That's a Donaldson style air cleaner - maybe cloned from Donaldson. Various versions of that are widely used.
You should be able to buy similar and adapt, if necessary.
Here's a Google search to get you started. Look at Google 'Images' as well as Donaldson's catalogs.
donaldson air filter housing - Google Search
I had played around on their site and couldn't find anything that really matched what I have (there is a TON of stuff on there). I'd like to keep it original looking if at all possible.
/ YM135D Air Filter Housing. #6
Apparently the 135 may have 2 separate air cleaners. A pre cleaner and a Reg. type Air filter. I'm not very familiar with the 135 and thought it was different looking it up. Fredricks should know what or which one you have. Or both? Reg. air filter is AF-2710 Precleaner filter is AF-6270. So somethings up no doubt with which one or what you have and then when you do know for sure they may have it. Or we will know what to look for.........
Carey
/ YM135D Air Filter Housing. #8
Hoye even showing both filters Southern Global only the Pre cleaner. So they should be able to help us move to finding which or what you have.
I am not looking for the actual filter, I am looking for the metal housing it goes inside of and connects to the intake. My precleaner was salvageable so I am good there as well. I need the part inside the red square in this picture. (picture is just off the web,not my actual tractor)
/ YM135D Air Filter Housing. #10
Got you now. That maybe a hard find. There's a man on CL. ATL. Ga. Farm and Garden that post a wide range of different parts. May try him. He has parts/tractors he doesn't list. The YM1500 has a side mounted air cleaner also 2cyl 15hp. your 13hp so they are about the same. Just a Automotive type filter setup.
http://www.mascus.com/images/productimages/6c1aacff/5fd5dc18.jpg
I sent e-mails to both the guy in Oregon and Georgia as well as Southern Global. we will see what they say.
I also will be getting my new hood decals printed up from a local sign shop. I couldn't find replacements for the original ones so I used mine as a template and scanned and re-drew them in AutoCAD. They should be exact matches to the originals.
I pulled the front end off last night and got it shot blasted this morning. They will be painted today. The front axle is going to take a bit to clean up before paint.
Got the front end back on except for the axle and driveshaft. Got a busy weekend so probably no more progress for a few days.
/ YM135D Air Filter Housing. #15
You're going to have that thing looking nice. Looks as though you have (had) a bellymower on it..? Too...
The goal is to make it as nice or Better than it was when my grandfather was alive.
Yes it has a belly mower also and a woods back blade. I have not moved the mower to my place yet as I have limited room to tear everything down. It's going to need the spindles rebuilt but is otherwise ok. If I can't find the parts for the rebuild I will have to make new ones myself.
/ YM135D Air Filter Housing. #17
I was thinking the early ym1500 or the other Grey versions with side filters may have the same filter? But I would think Aaron would know. But maybe he just answered that he didn't have one and not let you know which models to look for with one??
/ YM135D Air Filter Housing. #18
The 1500 filter came up 4-5 days ago so my guess was you found one or what you needed with your 135. The 135 with the guy in Ga. was a shot in the dark. I knew the 1500 was one of Fredricks models they sell so they should have it. I've been there and seen all the parts Tractors. That was UTDA days. Wasn't much doubt they have it but just figured you would check with them. Hard to believe they sell the Model but don't have any replacement parts. :rolleyes:
The 1500 filter came up 4-5 days ago so my guess was you found one or what you needed with your 135. The 135 with the guy in Ga. was a shot in the dark. I knew the 1500 was one of Fredricks models they sell so they'll have it. I've been there and seen all the parts Tractors. That was UTDA days. Wasn't much doubt they have it but just figured you would check with them. Hard to believe they sell the Model but don't have any replacement parts. :rolleyes:
I have not found the housing yet. I have sent e-mails to probably 7 or 8 places and only 3 of them even replied. The one craigslist guy Raffi was the only one who had what I was looking for but his looks in worse shape than mine. I was out of pocket for a couple of days so just getting caught up.
Still making progress on the tractor. I got the front axle cleaned,painted and re-installed last night. Also flushed out the engine and transmission before filling with fresh fluids. My decals are done so I'll probably get them Tomorrow as well as take the tins to get a quote on painting those.
/ YM135D Air Filter Housing. #20
None of the grey market models that Im aware of used a pre-cleaner style air cleaner assembly like that. We have lots of the YM1500 filter housings but he said he was looking to keep it original and wanted that original piece which we do not have. It looks like it was only used on the 135 & 155 and it was only offered as an option on those so there are not going to be a lot of them out there.
