Building my sunshade
/ Building my sunshade #1
sodamo
Super Star Member
Big Island, HI
Bobcat CT4545 LS XR4140H (Mine) BX2380 (wife’s)
Would really like a sunshade for my new LS XR4140H.
Would be easy to have cab envy, but I don’t have to move snow and most of my tractor time the temps are in 70’s, rarely hitting 81°F. If I had a cab, that might mean I’d have to mow in the rain, but the fields are to slippery when wet. That said, a bit of shade would be nice. Had a Tuff Top on my Kioti and it was great, thought I might go that way. Nope, either companies don’t ship to Hawaii or the shipping cost is prohibitively expensive. Guess I was fortunate years ago to get the TuffTop.
So my plan is to build my own. A FOPS style. But let me be clear, I’m not looking for FOPS protection, so basically a 4 legged unit.
Have some rough drawn plans and bought material. Using 1/8 aluminum square tube. 2x11/2 (wanted 21/2x11/2 but not available)and 11/4x1/14. Top will most likely be polycarbonate sheet.
I’m also planning a number of accessories. Already bought mirrors.
Likely not a speedy project, on and off with other stuff, but hope to keep thread current.
So today I was able to get the basic pieces rough cut. Got only one cut with my bandsaw and capacitor burned up, so need to replace before further progress.
Not a very accurate pic as some pieces aren’t oriented correctly, but just close to where going.
/ Building my sunshade #2
Looks like you are going to have enough structure to go ahead and build a cab. Of course, you probably don't need a cab in your location.
/ Building my sunshade #3
Considering the cost of a commercial one, it seems like you have too much idle time on your hands. Personally I like the ROPS mounted shades with nothing in my sight line. Very happy with the 'Tuff Top' and not that expensive at under 300 bucks.
LOL, agree. I keep seeing the possibility to add a rain screen, similar to golf cart, but I’m resisting.
Well Daryl, wish that were true, but have a whole list of projects I’m behind.
As I said, another Tuff Top was my 1st choice. but just a quick relook:
As for $, less than $200 at this point and likely less than and $50 to go, not counting the goodies I’m considering.
Don’t know how I’m going to like the posts in front but think the mirrors might mitigate a bit.
/ Building my sunshade #6
Back in the early 1960’s we had two Ford 3000s equipped with umbrella buggy tops similar to this.
We feature tractor the best tractor canopy tops, tractor umbrellas and tractor sunshades by Femco. We have many colors. And our tractor canopies, tractor umbrellas and tractor sunshades are proudly made in the USA!
They were later upgraded to Ford 4600s with cabs and AC but it made 12 hour days quite enjoyable cultivating 1/2 mile long rows especially on one farm that was oceanfront.
Great memories!
Well Terry, I do enjoy the ocean view when on the tractor 🤙
BTW, I had seen this site, another no ship to Hawaii ☹️
/ Building my sunshade #8
I have those lists as well, why I bought the manufactured top in the first place. I own a fab shop so building one from scratch wasn't the issue, time was.
On my open station, I went with mirrors mounted to the loader uprights, 2 mirrors from All States ag and some flat stock and I was in business.
/ Building my sunshade #9
Ah nice. sodamo your view is far superior. And no pesky rowcrops to run over when you doze off.
/ Building my sunshade #10
The picture of your framework shows a top that, I think, will be too tall. You need to clear your head when you step up and no more. The higher the top the less shade you get.
Planning on 92” from ground to top of frame. Need to double check my doors.
/ Building my sunshade #12
Maybe I missed something. I thought you were building a sunshade.
Yup, a sunshade. Did I confuse with my doors comment.? Sorry, meant the tractorshed door height. No plans for doors on tractor.
Made just a bit of progress today after getting a capacitor for bandsaw. Got the upright supports cut to proper size, holes for pins in rear, and bolt holes for fronts.
Using the Rops pins in rear and the two threaded holes at front of station. Seems quite solid, but thinking I might reinforce the bolted area and add a 3rd bolt from other direction.
Thinking I might need to use some rubber tape or something to minimize noise transfer.
/ Building my sunshade #14
If you want a windshield go with your design. Would you be able to mow if raining then consider building a cab but a simple sun shade heavy angle iron clamped to the rop with diamond thread aluminum for the roof. You should find a metal shop that sells it who can cut and bend it as you may wish. Get molding to slip on the edge to prevent getting cut by hitting an edge.
/ Building my sunshade #15
If going this route I would have the shop bend short sides with a formed lip for rain water. The bends would also provide rigidity and hamper vibration.
Great ideas, guys, Thanks.
Really doubt I’ll do windshield. Then I’d need wiper, would lose excuse not to mow in rain...
My initial top will likely be white polycarbonate roofing panel. Haven’t tried to source alum diamond plate.
A bit of progress, the 4 vertical legs, the 2 cross tractor top supports and the brace over the dash. Just temporarily held in place with screws for now as I’m expecting to disassemble then final reassembly. Still need the 2 top brackets that go lengthwise and possibly a cross brace at the ROPS.
I actually left it on today and brushhogged about 4 hours. Was pleased with the sturdiness, especially knowing it will get even better. The rubber tape mitigated any metallic noise.
Did you not find visibility impacted. Also found I now have a new handhold for climbing onto tractor
One consideration is to prewire when I do final assembly. The challenge being I don’t know what future uses I may want, but thinking at least 2 12vdc runs and an ethernet cable.
May investigate finding diamond tread aluminum for top. Recommended thickness? 1/8? 3/16? Other? Size will be around 44x60.
A fun project, especially given my lack of metal working.
Thought I had a pic. Will post one tomorrow.
/ Building my sunshade #18
sodamo I not certain what the best material for the top would be but IF you use metal the thicknesses you mentioned would be far too heavy and unnecessary.
I think 16 gauge would be more than adequate. You could have a sheet metal shop put an “X” crease on the top for rigidity and also have them form gutters.
I wouldn’t rule out a poly top of some sort also.
I’m happy to see that it’s coming together!
Pic from yesterday
Thanks Terry
Weight was primary reason I chose to make the frame from aluminum stock.
Guess My lack of metal knowledge is on display , but happy to have TBN to educate me.
Still haven’t fully ruled out the polycarbonate and it’s inexpensive enough for a 1st attempt.
2015 VANTAGE TRAILER 3 POD PNEUMATIC TRAILER (A67714)
2015 VANTAGE...
2014 CATERPILLAR D8T HI-TRACK CRAWLER DOZER (A65056)
2014 CATERPILLAR...
2005 little wonder high output blower (A64557)
2005 little wonder...
2006 HONDA ACCORD (A65057)
2006 HONDA ACCORD...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
2022 WEILER S450 SKIDDER (A65056)
2022 WEILER S450...
