3-Point Hitch John Deere 4410 3 point hitch issues
/ John Deere 4410 3 point hitch issues #1
JT4410
John Deere 4410
So I have a Frontier FP2206 weighs 995lbs. After running for a couple hours, the 3 point hitch operate very slow, if I run the RPM’s all the way up it lifts but struggles to get to the top. I bough the tractor February this year 2019 and they said they changed all filters and fluids. As anyone else had this issue?
/ John Deere 4410 3 point hitch issues #3
How many hours? Do you have a loader? It could be the pump is starting to go and not getting enough pressure. There is also a pressure relief valve. It is possible that is dirty or not adjusted properly.
1099 hours, yes have a loader and have no issues lifting heavy loads at all.
Where is the pressure relief valve located?
/ John Deere 4410 3 point hitch issues #6
2007 MACK CTP713 TRI AXLE DUMP TRUCK (A59575)
2007 MACK CTP713...
Wooden Rocking Chair (A61569)
Wooden Rocking...
KUBOTA L2501 TRACTOR (A62130)
KUBOTA L2501...
New/Unused Landhonor 100 Ton Capacity Hydraulic Shop Press (A61166)
New/Unused...
2009 Kubota M108S (A60462)
2009 Kubota M108S...
BUNDLE OF 10' RE BAR (A62131)
BUNDLE OF 10' RE...
