Rotary Cutter Brush Hog Blades COMING OFF
/ Brush Hog Blades COMING OFF
Well everybody, I got busy with 2nd cut hay and didn't have a chance to use the brush hog until the day before yesterday. What seemed to be the issue was that I was under-torquing the nuts. Apparently 4 feet of leverage wasn't enough. I put a rock bar in the open end of the pipe to increase leverage to ~9ft and tightened the **** out of both nuts, as well as reapplying loctite, still with the nord-lock washers installed. So far the nuts are staying tight as can be after taking out some bushes, small trees, and hitting quite a few rocks. Now to address some more specific comments:
jstpssng, I misspoke and was referring to the whole spinning hub as the stump jumper. You are correct, there is a large plate that the blades connect to which the stump jumper goes over. Both of those 3/8" plates are welded to the hub.
Gordon Gould, I was thinking it may have had something to do with the sandwiched plates deforming and allowing the nut to loosen. Maybe that was part of the issue but tightening the nuts to an incredibly high torque "pre-deformed" the plates?
Fuddy, I don't have threads for a 2nd nut or that would have been one of my first solutions.
Radios, one thing I was going for was keeping off the shelf bolts and nuts if possible. My local Tractor Supply has the bolt/nut set I am currently using.
As far as the whole grade 5/grade 8 debacle, I'm a mechanical engineer who grew up on a farm, so I have some experience there. Grade 5s are used in suspension and safety critical places because they STRETCH and give warning before a failure. They also commonly use grade 5 bolts for tightening heads to an engine block as they stretch predictably (torque to yield). Grade 8 will break swiftly and with little deformation, but are much harder to deform and break. All of the rotary mower bolt/nut sets from tractor supply that I have looked at specify grade 8 (e.g. ATRC11 Blade Bolt Kit at Tractor Supply Co.). Of course, even among grade 5/grade 8 there are different types of steel/hardnesses that can be used as all that the "grade" specifies is minimum yield strength.
Below should be a picture of my torque amplifier...
/ Brush Hog Blades COMING OFF #63
Glad you were able to get it going again, hope they stay tight for you and don't come off anymore.
/ Brush Hog Blades COMING OFF #64
I would tighten the nuts as tight as possible and weld the bolt/nut together on the top. The idea of a blade flying off at PTO rpms isn't appealing.
:thumbsup:
/ Brush Hog Blades COMING OFF #66
I thought maybe that was not enough torque using that short a bar . Helping my brother replace bearings in his large disk , ( 12' , 14' , 16' ??? , just dang big anyway ) , We had a 3' breaker bar , ( 1" drive ) with a 12' piece of pipe slipped on it and both of Us bouncing on it , ( Total weight of the 2 of Us , maybe 340 ) . No idea what type of torque We were applying , but the nuts would " Pop " and almost drop Us both to the floor :laughing:
Fred H.
/ Brush Hog Blades COMING OFF #68
Google “Sidewinder tire drive rotary cutters “
Yes, the tire rubs on top of the blade holder which spins the blade. I really like it! It works as a slip clutch and is VERY simple and robust. There are 2 giant roller bearings under the dust cap that hold the blade holder. 2 pillow blocks hold the tire. PTO runs the tire directly. The only downside is if cutting tall goldenrod, the stems can get between the tire and holder and cause it to slip, but that's only when your ground speed is too high anyway. Overall the thing is built very heavy duty and weighs even more than our set of 3 bottom plows.
2016 Chevrolet Caprice Sedan (A61569)
2016 Chevrolet...
Snap-On Gold Medal Tribute to Excellence Limited Edition 3-Bay Tool Box (A63118)
Snap-On Gold Medal...
2009 24ft Nautica International Rib with 25ft AmerTrai T/A Boat Trailer (A61569)
2009 24ft Nautica...
(INOP) CATERPILLAR AP500E ASPHALT PAVER 2 STATION (A62130)
(INOP) CATERPILLAR...
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
2014 Dodge Charger Sedan (A61569)
2014 Dodge Charger...
