Thumb for forks.
/ Thumb for forks. #1
Engineer42
Delaware
Mahindra 2555, Galion 503G, JCB 1400B
Ok, I need some help. I知 looking to build a thumb for my 48 forks. Just something simple, with one arm and one cylinder. I would use it took pick up cut limbs and other tree debris. I swore I remembered seeing a recent post regarding someone building one but I can稚 find it. Any help would be appreciated.
/ Thumb for forks.
Disregard last. A more diligent search found what I was looking for.
/ Thumb for forks. #3
Now you have me interested, where did you find it.
/ Thumb for forks. #4
Are you looking for something like this? It's really useful here with the people that deal with logs daily.
/ Thumb for forks. #10
I have been thinking of buying the thumb from green machine. I have a 2" receiver mounted on both my bucket and forks, I've been thinking of making a bracket to fit the recievers . Do you guys think this will work.
/ Thumb for forks. #11
IMO, I would not mount the thumb to a bracket that fits into a 2" receiver. Too much slop in the receiver and the thumb would probably exert too much force on it when closing. I would center notch out a piece of 36" x 3/8" angle to fit over the receiver, weld it to the bucket and receiver and bolt the thumb mount to that. I bought two thumb mounts and welded one on the bucket, one on the forks. That way I just pull 3 pins and move the thumb to which I want to use.
/ Thumb for forks. #12
I am considering this too, after using the thumb with forks I can see where the bucket thumb would offer different uses .
/ Thumb for forks. #13
[/B]
I actually mis-spoke. I welded angle brackets to the bucket and forks and bolted the thumb mount to the angle.
/ Thumb for forks. #14
You know, that actually would work for me too as I have a hook welded on center top of the bucket so some angle welded to the top front of the bucket would allow the thumb to function and not interfere with the hook. It is a thought. Do you have a pic?
NEW HOLLAND T4020 TRACTOR (A65057)
NEW HOLLAND T4020...
Deutz D1040-S (A64911)
WESTINGHOUSE PORTABLE ARC WELDER (A64276)
WESTINGHOUSE...
2014 HIPOWER 310 Generator (A67714)
2014 HIPOWER 310...
2014 MAC FLAMELESS HEATER (A68842)
2014 MAC FLAMELESS...
2009 PETERBILT 388 FLATTOP SLEEPER (A67714)
2009 PETERBILT 388...
