My New Kubota ZD1211 Mower
/ My New Kubota ZD1211 Mower #221
The SD Pilot did get covered with clippings.
I hate being limited to one direction with SD to keep clippings off of buildings & out of the road.
All of My Dang neighbors blow their clippings into the road : Burns Me Up !!!
You never realize how much being able cut on both sides of the mower reduces your mowing time, until you get a RD. I have my mower making beautiful stripes too, but I do cut at 4"
/ My New Kubota ZD1211 Mower #222
Yes sir I agree on RD : I Love mine :D
I’d buy a second ZD1211-72 SD IF I hadn’t just bought a new 15’ BH 2815 Cutter.
I mow Tons of Grass weekly here around the farm to keep varmits away.
/ My New Kubota ZD1211 Mower #223
I hope you are not planning to attack any of them like............
:eek:
Oh no lol
I don’t take it as serious as the guy 20 miles South of me did a few years ago when He burnt his neighbors house down, for not keeping their yard mowed.
/ My New Kubota ZD1211 Mower #224
Holy H$LL... That is one expensive rotary cutter. Congrats
/ My New Kubota ZD1211 Mower #225
Thanks
My 3pt Lift Type JD MX10 was taking way too long.
I kept it tho to mow a steep 700’ long bank & using the 2815 on the open fields.
It’s a Beast :D
/ My New Kubota ZD1211 Mower #227
I don’t wanna hi jack the ZD thread lol
I’ve got a separate 2815 thread with baffle option pix tho
/ My New Kubota ZD1211 Mower #228
Did you remove the rubber flaps and trim the center trans shield? Are you running Gator blades?
Not until I do a test run with for sure full throttle today.
/ My New Kubota ZD1211 Mower #229
:cool2::cool2::cool2: Discovered the problem with the windrowing of the ZD1211 RD and fixed it. Mowed grass for a bit that was to high and to wet. Waited an hour or so and mowed grass that was still to high but not wet. My grandson and I were using the F and the ZD and switched out and after mowing, no windrows and then after waiting a day still no windrows showing and then another day the grass is spread perfect on the yard!!!!! FULL THROTTLE on the ZD and about 90% on the F since it is under 10 hours use on it and when closer to 50 hours will bump it up to full. Have to go a little slower on the F with high grass and mulching kit and not doing full throttle but it spreads the clippings great. Entire yard looks wonderful today!!!!:cool2::cool2::cool2: FULL THROTTLE IS THE ANSWER and still with rubber across back and original blades, pure stock Kubota machine and deck, just full throttle solved the issue. Also grandson doesn't drive either one slow! :)
/ My New Kubota ZD1211 Mower #230
Other than break-in : idk why anybody would want to mow less that Wide Open Throttle (WOT)
/ My New Kubota ZD1211 Mower #231
Coming from almost 60 years in the gas engine world I've had to adjust to the full throttle diesel mowers world for the last 12 to 15 years. The ZD is 40+ hours now so close enough for me to now do wide open throttle ito get the grass cutting results I want and expect from Kubota mower.
/ My New Kubota ZD1211 Mower #235
I always mow out, turn around & come back.
Never in circles.
After removing rear rubber flaps from RD deck & mowing weekly :
I’ve discovered mowing 90 degrees to the previous week helps windrowing a little bit.
I mow North & South one week then East & West the next.
In my bigger open areas, I have mowed at 45* in between weeks too here & there.
I don’t like the dead grass windrows from Heavy Thick Grass But I Love my ZD1211-72RD Machine :D
/ My New Kubota ZD1211 Mower #236
Never in circles.
I to deviate my mowing pattern. I do across my yard and then from street to house and then diagonal from mailbox on front corner to burn pile toward opposite corner and then from drive way toward neighbors corner of his driveway. My grands on now helps and he wants to always do street to house so I have to jump on one mower and start the pattern for the mowing session and then get him sucked in to my pattern and I quit.:D I do around 3 precious to me 3 pre bearing pecan trees and sometimes the circle just goes out and out and out and out till I have a big circle and then I'm at the other pecan tree and start my circle and keep it up till I reach the beginning of my next circle and just drives my wife and grandson crazy when they see my three big circles. Got many trees but usually, usually I say only do the circle cut on the pecans, my precious pecans.:cool2:
My grand loved the F over the BX and I think he still does butttttt he may have a slight preferencefor the ZD over the F, he hesitates when I ask his preference. At a 14 year old wanting to drive boy the spinning ZD is quite an attraction and they both ride good so guess BX mowing is history for sure.
/ My New Kubota ZD1211 Mower #237
:D..........No, I just got the F and ZD and RTVx1140 this year, the ZD was used with 37 hours, so no not this year any more trading. This may be my last trading bout...........:D:laughing:
Is that even possible? 😀😀😀 Thanks for keeping us up to date on Kubotas of all kinds!
/ My New Kubota ZD1211 Mower #238
" All you do is get a set of holders K5955-34380 and cut the ends down to 1.120" and buy whatever blade you want to use. Plenty available. "
I'm planning on doing this shortly on my 72" side discharge. Still looking for the best blade.
/ My New Kubota ZD1211 Mower #239
Oil filter rubs against lower radiator hose.
Hose is wearing thin.
/ My New Kubota ZD1211 Mower #240
I checked my radiator hose. It clears the oil filtHer.
Would the Oregon G6 Mulching Gator Blades sling grass out a SD Deck OK if blade holders was converted to accept the smaller center hole RD blades ?
Also, are the RD & SD blades exactly the same length from tip to tip ?
2018 Chevrolet Traverse SUV (A60352)
2018 Chevrolet...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
2006 TRAIL KING ADVANTAGE PLUS RGN/DETACH TRAILER (A60430)
2006 TRAIL KING...
2015 Freightliner M2 106 AWD Altec DM478BTR Insulated Digger Derrick Truck (A60460)
2015 Freightliner...
John Deere XUV825E (A61306)
John Deere XUV825E...
(2) 36"X8' ADS DRAINAGE PIPE (A60432)
(2) 36"X8' ADS...
