Kubota M95 Hydraulic issues
/ Kubota M95 Hydraulic issues #1
Bullseyefarms
Kubota M9540
Hey all, looking for a little input here... Currently having hydraulic issues with my M95. When I activate any lever the system doesn't hold steady pressure. The steering feels sluggish, and I have no power going uphills. Already checked the quick connects, everything thing seems ok, fluid level is good, not foamy or aerated. Any suggestions/info would be greatly appreciated. Thanks in advance!
/ Kubota M95 Hydraulic issues #2
For the Hydraulic problem do you have a pressure gauge to check system pressure? If not, you should consider one as it will tell a lot about what is happening. Also has the filter been changed lately? If not I would start there. A common problem also is trash holding a relief valve open. Sometimes even a damaged O-ring on the relief can create a similar issue.
As far as losing power uphill I would think that is unrelated to the hydraulic issues. What happens when you lose power? RPM drops?
Hope this helps some and welcome to TBN!
/ Kubota M95 Hydraulic issues #3
Your tractor has 2 x hydraulic pumps, it "appears" ALL hydraulics are affected, as noted previously, filters would my first port of call, and suction line to pump, and possibly pump drive gear or spline.
/ Kubota M95 Hydraulic issues #4
assume you have hyd shuttle? is it engaging fully in forward/ reverse? not sure this is your problem, but i've had to adj the hyd shuttle cable tension in the past. on one occasion had to replace a sticking hyd shuttle cable, but this may not be your problem. just a thought
2018 CATERPILLAR TL1255D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
Caterpillar 70in Loader Forks and Frame Attachment (A61567)
Caterpillar 70in...
2019 JCB 457 (A60462)
2022 John Deere 317G Compact Track Loader Skid Steer (A61567)
2022 John Deere...
JOHN DEERE 6105E TRACTOR (A62130)
JOHN DEERE 6105E...
Tan Jet Dock Drive-On (A59228)
Tan Jet Dock...
