Loader FEL loader safety prop
/ FEL loader safety prop #1
Smokeydog
Elite Member
Knoxville, Tennessee
Kubota B26, M59, M5030DT
Often raise the loader to better access the engine for maintenance. Cleaning radiator/screen often required during mowing season. (Radiator Genie tools are the best!) Had a redwood 4x4 that was light and strong for a prop. The M59 has a well thought out metal U-shaped cylinder prop attached to the loader for safely blocking the loader in the raised position. More common on construction equipment. Ag tractors are slow to include this important piece of safety equipment.
Guilty of not always propping up the loader while working underneath. All tractors can hurt or kill you.
Would like to make something for the B26 loader. Anyone make a loader cylinder prop? Prefer something attached and quick to deploy/store like on the M59. Brainstorming for ideas.
/ FEL loader safety prop #2
Why not just copy the design of the M59 lock, and size it to fit the B?
Most likely the best idea. However I’ve seen some very cleaver ideas on this forum that might be better.
/ FEL loader safety prop #4
I guess it depends on how high you need it propped up. I just use a couple saw horses under the bucket for my needs.
Cheers,
Mike
/ FEL loader safety prop #5
Use an L or U shaped block on the cylinder rod.
Bruce
That prop on the backhoe stabilizer cylinder rod for leak down or antitheft?
/ FEL loader safety prop #7
That was just the first photo I found to illustrate the concept. Imagine a longer one placed on a loader cylinder rod when in the up position.
Some more:
Bruce
/ FEL loader safety prop #8
Very good ideas!
Just the other day I saw a guy raise another guy up in the tractor bucket to use a chainsaw to trim some branches... surprised Darwin didn't contact either of them that day...
/ FEL loader safety prop #9
Cut a piece 2X2 angle iron the correct length. Store angle iron in frt cross tube on your loader. Utilize a zip tie to secure angle iron on boom cyl rod.
/ FEL loader safety prop #10
Very good ideas!
Last Wednesday 2 guys, 77 and 63, were trimming trees standing on what is described as a pallet in forks of a telehandler in Southern Minnesota. They were 30 feet high when the telehandler rolled. 63 y/o died in the fall, 77 y/o transported by helicopter in critical condition, and 38 y/o telehandler driver non-life threatening injuries.
When I grew up loaders on tractors were rare. Had a manual trip manure bucket loader on a 135MF was something special. Loaders are more common now and also are accidents. Don’t think loader cylinder locks were designed for a working load. Man lifts, bucket trucks and telehandlers often have pilot check valves to prevent collapse from a hydraulic line failure. My tractors don’t have that.
For safety equipment to work properly it helps to be easy and available. I added fire extinguishers, mirrors, grill guards, chainsaw and chain holders to improve operational safety. Decades of farming, construction, industrial work experience knows its wrong to be underneath a loader without securing it. I’ve used ratchet straps and chains to secure loaders up for major engine work because of lack of a proper loader cylinder lock.
Hopefully have time this winter to attempt to make a loader cylinder lock for the B26.
Work safe.
Nice stands!
Just installed newly re-enforced grill guard on the M59. Used the loader lock to safely work under the loader.
Studying the safety cylinder prop on the M59 to make something similar work on the B26.
11 pieces total.
5 pieces of steel formed, machined and welded for the prop.
3 pins.
1 lanyard.
1 storage welded tab with pin hole.
1 rubber bumper to protect cylinder rod.
B26 loader geometry about same just scaled down.
Owners of new B26, L39, L45 or similar size tractors have such a safety prop?
/ FEL loader safety prop #15
Very good ideas!
Not uncommon, actually. In our younger days, that would have been me up in the bucket with the chainsaw and my wife driving the tractor. Well, here we are many decades latter none the worse for it.................Thankfully
/ FEL loader safety prop #16
I do it as well and I'm 70.
/ FEL loader safety prop #17
My Branson shipped to the dealer with 2x2 angle iron on both loader arms. I think they ship with the loader up to maximize space on the trailer. I got a pair from the dealer, painted white so I wouldn't miss them and use ladder tied to secure them. Depending on what I'm doing, I sometimes have to store the tractor in the barn with the loader up. This keeps the cylinders from letting the loader down as well as making it safe to work under them
/ FEL loader safety prop #18
Call me crazy, but a couple of 2x4's jammed under the loader arms does the job.
If the hydraulics did fail, the load on the studs would be static so they should be able to keep the arms held up.
Needless to say I don't spend any extra time standing under it when I need to work in that area:p
Got to be careful when propping up the loader incase something moves, slips, gets bumped or fails. Makings of a deadfall trap.
Last Friday I was bush hogging a mile from the house. Monitoring temperature and twice had to clear vegetation off the grill screen. So having something handy to block the loader up while clearing the grill and radiator screen was safer.
2007 FORD F750 XLT SUPER DUTY SERVICE TRUCK (A58375)
2007 FORD F750 XLT...
2014 Bobcat T550 Compact Track Loader Skid Steer (A61567)
2014 Bobcat T550...
2012 Ford F-750 Pak-Mor 16 Yard Rear Loader Garbage Truck (A61568)
2012 Ford F-750...
CASE ROOT PLOW (A58214)
CASE ROOT PLOW...
Wooden Rocking Chair (A61569)
Wooden Rocking...
2017 Load Trail 3.5 Ton T/A Equipment Tilt Trailer (A61568)
2017 Load Trail...
