Buying Advice New L3560 Limited and Standard Versions
   / New L3560 Limited and Standard Versions #122
I'd love to hear some more feedback on the new 3560 LE models. How are they treating you? Any new strengths or weaknesses discovered?
   / New L3560 Limited and Standard Versions #123
That's not true according to Messick's, in Neil's video. It has the exact same transmission as the standard model.
   / New L3560 Limited and Standard Versions #124
I love my L3560 cab.
   / New L3560 Limited and Standard Versions #125
I just hit 109 hrs on my l3560 hstc LE. I still love it. Feels stronger than my old mf135. The antenna stud is week. I thought it was loose one day so I reach out of the cab to tighten it and broke it off. I got another on the way from an online marine shop.
   / New L3560 Limited and Standard Versions #126
have you broken a high mounted rear flasher yet?
I knocked out the lens on one side. Have since removed both brackets and lights.
   / New L3560 Limited and Standard Versions #127
Yes I have. I stopped at a pilot truck stop and they sell an assortment of flashers I picked up one to test and it fit perfect. I will get another next time I am by there. It’s was about $13. I am slowly getting interested in wiring up some work lights but I would like to use factory harness.
   / New L3560 Limited and Standard Versions #128
The LED hazards I got off Amazon for my cabbed Grand cause radio interference. Stick with old halogen bulbs if you listen to a radio. There were only 1 set of LED hazards I could find after a suprising amount of searching & they were chrome instead of black.
   / New L3560 Limited and Standard Versions #129
There is no controller or harness for front work lights on the LE, I ended up with two work lights(one front, one rear) running off the optional rear switch.
   / New L3560 Limited and Standard Versions #130
You need mirrors on ANY cab model, you don't need a right hand step (never used mine, never gotten off that side anyway, the loader tower is in the way. Don't need lights either, I changed my sealed beams out to LED's a long time ago. My tractors don't come with a mid mount pto and I have no use for one anyway.
2014 Ford Taurus AWD Sedan (A55853)
2014 Ford Taurus...
UNUSED (2) 7000# DROP AXLES W/ BRAKES (A54756)
UNUSED (2) 7000#...
2014 CATERPILLAR 303.5E CR EXCAVATOR (A52705)
2014 CATERPILLAR...
KUBOTA L2501 TRACTOR (A54756)
KUBOTA L2501...
FIRESTONE 9.5L-15 4 RIB TIRES (NEW CONDITION) (A55301)
FIRESTONE 9.5L-15...
2009 Honda Pilot AWD SUV (A53424)
2009 Honda Pilot...
