Which Tooth Bar to get??
/ Which Tooth Bar to get?? #1
suburbanfarmer
Western NY
JD 3238e & 3228e
The titan beats everyone hands down in price but cant find any reviews on it.
/ Which Tooth Bar to get?? #8
Piranha Tooth Bar beats a regular tooth bar hands down for what you need it for IMO.. Lots of people here have them and like them, they have kind of a cutting edge to them that regular bars don't.. Probably $309 for you're 61 inch outside diameter bucket..
Just read through the reviews, shipped its $354..So about $100 over Titan.
According to the reviews does everything I will need it to do for me.
/ Which Tooth Bar to get?? #10
What's your soil like?
The Piranha excels in clay, loam, etc. but if you have a lot of decent size (softball plus) rocks a longer "tooth" (like the ones i your links) is usually needed.
All my soils are sedimentary and I've made great use of my piranhas in slicing just below the soil surface when clearing briars and brush.
The Piranha excels in clay, loam, etc. but if you have a lot of decent size (softball plus) rocks a longer "tooth" is usually needed.
It is mostly clay and has rocks when I tilled a section. But honestly dont need it to dig out rocks but clear land to make trails.
/ Which Tooth Bar to get?? #12
/ Which Tooth Bar to get?? #14
I don't use it for cutting and ripping brush. I do not think it would do well at that. It's certainly a heavy duty digging tooth bar.
Trying to cut brush with a bucket doesn't work so well for me. The bucket with or without the tooth bar rides up over brush like Honeysuckle. Raising the whole tractor. Nothing for the bucket or teeth to bite into.
I understand what your asking and looked hard at the Piranha before buying the Long. I was never convinced that the Piranha would cut and rip rush. The sharp edges on the Piranha certainly would held but sharp edges on a tooth bar, at least the way I use one, aren't going to last very long.
Thanks for the reply. No serious digging needs as such. Like I said more about tearing out brush
/ Which Tooth Bar to get?? #16
The piranha bar would work best for your needs. Cutting or ripping small brush and vines at ground level. Would be better than a regular bucket for digging but not as good as a tooth bar.
The tooth bars are great for digging and can be used somewhat as a rake for both vines, small limbs, etc. Spreading loose soil somewhat evenly also. Just like a yard rake. Not worth a lot for cutting brush.
/ Which Tooth Bar to get?? #17
The Titan bar with the rolled up teeth is trash. They won’t cut with the bucket level. You have to roll the bucket down to engage the teeth and then it’s too aggressive. Second major flaw is the teeth are too big. Teeth are supposed to be sharp. Here’s what a tooth bucket is supposed to look like. IMG_7242.JPG
/ Which Tooth Bar to get?? #18
Tear out brush/roots and occasional moving dirt/clay.
The last 2 days, I was on my tractor tearing out brush with roots and all that stuff, leveling dirt, all with the ratchet rake strapped onto the bucket. That thing is legit. It's cost me $300 with $40 shipping. I also bought their snow edge. Same price.
i have the snow edge and really like it. Wasnt sure about the ratchet mechanism and how much force it would withold.
/ Which Tooth Bar to get?? #20
I have the ratchet rake.
It is very effective for tearing out brush & vines.
2021 DITCH WITCH HX30G VACUUM TRAILER (A63276)
2021 DITCH WITCH...
2014 Magnum 7696BLA Light Tower (A59213)
2014 Magnum...
Case 1020 25ft Draper Head (A63118)
Case 1020 25ft...
2018 BOBCAT E50 EXCAVATOR (A64279)
2018 BOBCAT E50...
Cab Cam Monitor (A63117)
Cab Cam Monitor...
2014 International WorkStar 7500 T/A Dump Truck (A61573)
2014 International...
