Thomas
Epic Contributor
- Joined
- Apr 6, 2000
- Messages
- 32,585
- Location
- Lebanon,NH.
- Tractor
- Kubota B2650HSD w/Frontloader & CC LTX1046 & Craftman T2200 lawn mower.
:thumbsup: Whatever your doing keep it up.
Why are the deer in the south so small?
The deer here in Maine are big deer, if one had a rack like the pictures here it would be 275lbs.. It's a mystery to me why the deer aren't bigger in the south, you would think with easier winters they would be able to eat grass longer and keep summer weight longer into winter..IDK..
Deer don’t eat grass. They eat forbs and mast. I can only speak for the south western region and because this region does not get as much rain the summer can be a challenge for deer to find adequate nourishment.
I think it is all about the food supply. Our forrest deer here in Southwest Missouri is fairly small as a rule while in upstate Missouri in Farm country where there are lots of corn crops to eat they are generally much larger.
The white-tailed deer is highly variable in size, generally following Bergmann's rule that the average size is larger farther away from the Equator. North American male deer (also known as a buck) usually weigh 68 to 136 kg (150 to 300 lb),[9] but mature bucks over 180 kg (400 lb) have been recorded in the northernmost reaches of their native range, specifically, Minnesota and Ontario.
The Florida Key deer are quite small. Also from wikipedia: Key deer - Wikipedia
This deer can be recognized by its characteristic size, smaller than all other white-tailed deer. Adult males (known as bucks) usually weigh 25-34 kg (55-75 lb) and stand about 76 cm (30 in) tall at the shoulder.
IDK, but I've heard that it has more to do with body heat. In cold climates stocky builds retain heat better than skinny ones, in hot climates, skinny ones can shed heat better than stocky ones.
