Bush hog not cutting
/ Bush hog not cutting #1
Jsg32780
Kubota
Have a Land Pride 1680 bush hog. It will not cut. It comes on but won稚 build enough rpms to cut anything. I did notice with tractor off and pto engaged the pto shaft will not move but blades will. Any help will be greatly appreciated.
/ Bush hog not cutting #2
Could be a blown shear pin or the slip clutch needs adjustment.
Welcome to TBN & the forum - Jsg32780.
Thanks! Enjoyed it so far. Yeah I have read some stuff about that. Is it possible for it to have a shear pin and slip clutch or do they usually have one or the other.
/ Bush hog not cutting #4
Generally just one..... Shear pin or a slip clutch....But not both.... Also check the blades and stump jumper are not just spinning on gear box out put shaft because you have loose castle nut and lost cotter pin .... Generally blade and stump jumper are tortures to 400-600 ft-lbs but have been know to come loose.... With all systems off (engine) start tuning shafts and blades and look to see where motion stops, you problem will be really close to where motion stops....
Dale
/ Bush hog not cutting #5
How did you determine blades with turn, but not PTO shaft?
Problem has to be between PTO shaft and blades. Slip clutch? Sheared bolt? Gear box? Output shaft to blade holder? One of these four things has to be it.
And as stated before you will have either a slip clutch or shear bolt, not both. So really only 3 things to check.
/ Bush hog not cutting #6
Remove the PTO shaft from the tractor. Then put a rod/bar into the U-joint and turn the PTO shaft by hand. See what turns and does not turn. Should make it real easy to determine what's not working!
/ Bush hog not cutting #7
You didn't say if your Kubota has a switch or a mechanical lever for the PTO.
I had a similar problem with my Deere 4720, the problem was the PTO would slip due to insufficient pressure on the clutch. The valve that operates the clutch had crud in it from a previous repair (Teflon tape.)
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A63689)
2017 Yale GLC050VX...
2023 Case TV450B (A62177)
2023 Case TV450B...
2008 Case IH 2152 Combine Header (A63688)
2008 Case IH 2152...
Fellabuncher Dangle head, PARTS ONLY (A62679)
Fellabuncher...
30ft Highway Trailer Co. Lowboy (A63118)
30ft Highway...
Pallet of Two Pivot Wheels & Tires (A62177)
Pallet of Two...
