Rotary Cutter Bush Hog cutter issue. Help!
/ Bush Hog cutter issue. Help! #1
sawtooth
Eden NC
Ford NAA, Ford 2810, Ford 3910-1, Ford 3910-2, Ford 4600SU, Massey 2660 HD, Massey 461, Grasshopper 725D, Grasshopper 900D
So I have a lightly used 6’ BH 286 cutter. Never had issues with it but today tried to slide the quick coupler onto the pto shaft of the tractor. I can get it started to where the first de-tents are on the shaft but then it won’t go any further. The pto is well greased and I don’t see any damage on the male or female ends. Anyone know what could be causing this? Just had it hooked up two days ago with no issue so not sure what happened?
/ Bush Hog cutter issue. Help! #2
I find sometimes rotating the pto shaft a bit can help ( by hand, with the pto shaft in neutral and the engine off). Lifting the brush hog so it’s level as pissible with the pto may help too; don’t have your feet under it though.
I did already try that but good idea. One thing I did find is that none of the 3 little bearings presses in. These are the ones located on the cutters quick coupled. Should any of them press in? It’s like I can’t get pass that point.
/ Bush Hog cutter issue. Help! #4
Yes, spray PB blaster or whatever you have handy. As you push in the collar it should unload the ball bearings and drop into the detents. Spray in there also.
Oh, forgot, first make sure the PTO collar can fully slide back all the way. So a good soaking may be in order.
Hope that helps a bit....
Best regards...
/ Bush Hog cutter issue. Help! #5
Best regards...
+1. I have a Rhino RC that got stubborn and little PB Blaster solved the issue. Years of grime and grit can get packed around those bearings.
/ Bush Hog cutter issue. Help! #6
Best regards...
AND, quit greasing it!!
Wipe that sticky crap off everything, and then spray "everything" with WD-40 (or similar) EVERY TIME you put anything on that pto! (pto/coupler/shaft where it slides ect.)
I've been doing that longer than most here are alive, never used dirt grabbing grease and have NEVER had a pto problem.
SR
/ Bush Hog cutter issue. Help! #7
SR
Yessir...good ol hard dry grease, lots of threads here now on how to take them apart...lol....
/ Bush Hog cutter issue. Help! #8
I pull the collar back all the way, and use a screwdriver to push the stuck ball bearings into the detents, then slowly slide the piece onto the pto shaft keeping the collar pulled back. It works for me.
/ Bush Hog cutter issue. Help! #9
I use a wax based motorcycle chain lube where I need a lube that will not attract dirt and dust.
You may have to use carb cleaner if its got grease and dirt packed in the joint.
/ Bush Hog cutter issue. Help! #10
SR
^^^^^What he said, the grease is the problem^^^^^
Had no idea but makes total sense. This will sound funny but my grandfather always greased the pto and coupler so I have done the same. Seems totally stupid now that this issue has came up. Lol
Thanks guys.
/ Bush Hog cutter issue. Help! #12
Thanks guys.
Sawtooth,
Your grandfather probably used it 3 times as much keeping it from hardening up as well! :laughing:
/ Bush Hog cutter issue. Help! #13
I had a coupler that hadn't been used in decades. It hung up about the same place yours is hanging. I couldn't see any definite obstruction among the spline slots so I fook a file and worked on places where I thought there 'might' be obstructions. It finally went on and I still don't know which spot where I filed did the trick.
/ Bush Hog cutter issue. Help! #14
Thanks guys.
I had an old cutaway harrow when my grandfather was in the way out. Dementia must have been taking over when he took his oil can, filled with used motor oil, and proceed dribble it all over the part of the tongue I had to handle to hook up. There was no moving part on that section of the tongue. I can see him now, flexing the bottom of the can and grinning like a possum. Used motor oil is nasty stuff.
2019 KOMATSU D61PXI-24 CRAWLER DOZER (A62129)
2019 KOMATSU...
2019 Kenworth W900 Ext. Day Cab w/ Wetline (A62613)
2019 Kenworth W900...
10ft Cattle Panels (A64047)
10ft Cattle Panels...
Kubota Z232 (A60462)
2019 Kenworth T270 Flat Bed Dump Truck, VIN # 2NKHHM6X3KM358768 (A61165)
2019 Kenworth T270...
2017 Skyjack SJ16 500lb. Manlift (A61567)
2017 Skyjack SJ16...
