Buying Advice JD 1025R or MF 1725M
   / JD 1025R or MF 1725M #1
51Howard
None
New here, but looking for some advice on a tractor for my new house I’m building. I’m very familiar with heavy equipment as that’s what I do for work, but not familiar with these small tractors. The main use will be mowing and snow blowing with some yard work with the FEL. I was looking at 3 tractors, jd1025r, mf1725m and Kubota bx2680. The BX got ruled out due to the treadle peadle or what ever itç—´ called, and lack of lifting compacity. My JD1025R quote came in at $22,725 with fel, 60 inch mower, 54 snowblower, and weight box delivered. I got the same price for the 1725m with same attachments but a 50 snowblower.
JD pros
Great reputation
Very easy fel on and off
Very easy mower deck on and off
Great lifting capacity
Tight turning radius
3 point adjustments
JD cons
No skid steer fel, only there own set up
Plastic hood and side panels
Odd ROPs and tall
Fuel gauge on side
One operation fel
MF pros
New 1805 fel with skid steer bucket
6 year 0% interest
Great gauge cluster
Can do two movements at same time with fel
Can run both pto at same time
MF cons
Not as easy fel on off as JD
Not as easy on off mower
Seat wasn’t as comfy
Tilt wheel was awkward to use
So both have good and bad, so I’m sure either would make me happy. I’m leaning a little towards the MF for the skid steer bucket and 0% for 72 months. But the JD fel and mower on and off were very easy to do compared to the MF. I know the 1725m is new and not much feedback, and that also concerns me. Issues on forest year models is common. So just looking for some honest feedback.
By the way, love the site. Good info here.
   / JD 1025R or MF 1725M #2
I have a sneaking suspicion you could cut a few thousand off that price by going blue as I did (and several others here).
It was on list, but nearest LS dealer is 1.5hrs away. The MF is 10 min away and JD I’d 15 min.
   / JD 1025R or MF 1725M #4
I had the 1705 for four years, I liked it very much with that said personally I like the Deere a bit better because of ease of use and comfort compared to my 1705, have never sat on the new Massey..
   / JD 1025R or MF 1725M #5
I'm pretty sure you could get the SSQA as an added (for $) option on the Deere.
   / JD 1025R or MF 1725M #6
You can get a SSQA conversion for the JD, but consider the logic of why JD has their own system. Tractors in this class have limited lifting capacity and SSQA systems and accessories are quite heavy, because they are designed for much heavier machines. You will lose much of the lifting capacity with an SSQA. There are many accessories available for the JD system and I have built a number for myself because the system is so simple.
The SSQA is a consideration but it's not automatic that having SSQA is an advantage.
   / JD 1025R or MF 1725M #7
I don't plan on making enough trips to my dealer for that to matter. The $5,000 or so lower price would far outweigh a few minutes of driving.
Nice points and never thought about that. Is the $22,725 for the JD a good price. It was close to $4000 off msrp.
   / JD 1025R or MF 1725M #9
I can not comment on the MF but I own a JD2025R which is a larger version of the 1025. A couple of things I like is the easy off and on mower deck and the quick attach for the bucket. Unless you have a lot of skid steer attachments laying around it should not be an issue. The JD system is so simple and adds no weight.
   / JD 1025R or MF 1725M #10
OP, it comes down to which one is going to work the best for you.. Both well made machines..
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
2011 GMC Yukon XL Denali (A56859)
2011 GMC Yukon XL...
2017 John Deere 5090GN (A53317)
2017 John Deere...
Brown Metal Roof Panels (A55758)
Brown Metal Roof...
2006 WARREN 30' DUMP TRAILER (A54756)
2006 WARREN 30'...
SHOP FAN WELDING CART (3) JACK STANDS (A54757)
SHOP FAN WELDING...
