Buying Advice JD 1025R or MF 1725M
   / JD 1025R or MF 1725M #11
Nice points and never thought about that. Is the $22,725 for the JD a good price. It was close to $4000 off msrp.
I would say that getting over 15% off list is a very good deal on a John Deere.
   / JD 1025R or MF 1725M #12
instead of adding weight box, I would think about filling the tires, granted tires are all small on that tractor might not get the desired effect,. But if you can add the same amount to the tires as the weight box would be that that eliminate you having to take the box on and off.
   / JD 1025R or MF 1725M #13
Loaded tires are NOT a substitute for rear ballast, you need to have weight behind the rear axle.
   / JD 1025R or MF 1725M #14
no but on that size machine and depending on what you are doing might be fine. not moving tons of weight with that thing.
   / JD 1025R or MF 1725M #15
On that size machine it's even more important! No matter what your doing...
The Loaders owners many details what is required
Both JD dealer and MF dealer did not recommend loading tires. They both agree weight box would be more useful.
   / JD 1025R or MF 1725M #17
Loading tires help with traction, rear ballast helps with using a front end loader. Even if you can lift the load fine and tractor is stable, the front end will thank you for using rear ballast. :2cents:
2014 Ford Transit Connect Cargo Van (A54814)
2014 Ford Transit...
2015 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A55973)
2015 Peterbilt 567...
2014 BMW 320i Sedan (A55758)
2014 BMW 320i...
CATERPILLAR 30 1/2" PIN ON BUCKET (A52706)
CATERPILLAR 30...
1408 (A57192)
1408 (A57192)
2013 Ford F-750 Pak-Mor 16 Yard Rear Loader Garbage Truck (A56858)
2013 Ford F-750...
