Security & Theft Ignition damaged by thief
/ Ignition damaged by thief #1
rzinkel
John Deere 790
I have a John Deere 790, which I recently purchased, and yesterday a bad person tried to start it without the key and damaged the ignition/key slot so that I can't insert my key to start it. The entire mechanism now seems loose as though maybe he tried to take it apart/out or ??? How do I remedy this? (I'm an older woman and this is my first tractor, so I know next to nothing about them, so please be specific) Is this something I can deal with myself? Since I can't start it I can't take it anywhere :(.
/ Ignition damaged by thief #2
I would suggest the best option may be to call the local dealer, explain your situation, and have them come out to your property to remedy the issue.
/ Ignition damaged by thief #3
Sorry for your troubles. The JD790’s are great tractors. If it were me I’d see if a tech from a John Deere dealership could come out and give you an estimate for repair.
If the JD dealer costs too much then see if a local mechanic can bypass the key ignition switch and install a push button starter switch, perhaps hidden so that next time the thief tries to steal it he can’t figure out how to start it.
/ Ignition damaged by thief #4
Your homeowners insurance will cover it, less the deductible.
Our closest JD dealer is in Medford, Oregon which is a 3 hr. RT from here :(
My homeowners insurance specifically says that it covers no vehicles. Even if it did my deductible is hopefully much more than this will cost to repair ($500). At least I sure hope it's no where near that much. The tractor wasn't stolen... he just tried to but didn't succeed.
Thanks. No JD dealers anywhere in the area, but there is a guy who sells other brands and used ones. I may have to go talk with him it's sounding like.
/ Ignition damaged by thief #9
Any local mechanic should be able to install a switch. The question is how are you going to keep the tractor safe from theft is the POS comes back??
Sorry this happened!!
/ Ignition damaged by thief #10
If the new switch is plugged in but installed in a more secure location, then it might not happen again. Leave the old switch in the original location for the thieves to play with.
I know who it was so hopefully local sheriff will convince him to stay away. I'm considering getting a game cam to keep where I normally park it.
/ Ignition damaged by thief #13
Just an FYI.. there are different switches for gas & diesel tractors.. BE SURE to get the correct one.. or some components wont work.
Its just a matter of swapping wires.. they push on & pull off {most of them}
AND the switch is marked/ abbreviated on the underside..
IF your not confident in your skills, get a neighbor to help & pay'm 50.00.
Sorry to here about your trouble..
Thanks for that bit of info. I've been trying to find info on how to remove the existing ignition key module from the tractor but haven't found that tidbit as yet. If I can find that I'll know much better how confident I am or am not. I live in a remote location in the mountains so it's not easy to get someone to come out to my place to do repairs without costing quite a bit just to get them here. If it's the one posted in the Ebay link here, once I get the damaged one out it would look to be a simple switch at that point.
/ Ignition damaged by thief #15
I have 4glte game cams and a plotwatcher keeping me informed.
/ Ignition damaged by thief #16
I've replaced the ignition switch on my Kubota, I suspect your JD will work the same way. There is a cover that screws onto the key switch, Get a large pair of pliers and some soft rubber (or equivalent) for padding the jaws so you don't scratch the cover and unscrew the cover. Once the cover is off, the switch can be pushed thru the console and drop out the bottom. Unplug the connector and plug in the new one. Reverse the process to complete the replacement.
I couldn't find a picture on the web, so I'll get one later today to show what I'm trying to describe.
/ Ignition damaged by thief #17
Don't you have a mechanic or handyman in your community? Replacing an ignition switch + key is a common job. Any handyman mechanic can simply use the serial number of the JD790 to order the part and then either you or he can install it. I'm betting it won't take but an hour to do it right.
Again, this is a common job for any mechanic to do. It is even easier because those old JD790s are way easier than the complex ignition systems found on newer tractors.
In fact, I just looked on Ebay under "JD790 ignition switch". There are several sellers for under $30. The problem is to get one that is identical to yours. Check by tractor serial number. Frankly, I'd probably buy from a regular John Deere dealer who sells parts online. Just call any JD parts dept. Order with a credit card. With the switch in hand, it will be obvious how to replace the old one.
good luck, you can do this...
rScotty
/ Ignition damaged by thief #18
If this is the ignition switch it should be an easy swap out if you have a friend that is handy.
https://www.ebay.com/i/123818195031...MIjq3kvfuN5AIVDtRkCh2cTglFEAQYASABEgLLafD_BwE
The ebay switch is the correct P/N AM876787. List price is $30. You might want to see if a local dealer will mail it to you first class mail.
Install is simple. Screw off the front retaining ring and remove from the back. Wiring will be connectors that just unplug. Plug the new ones connectors to the wiring harness, install from the back, install front retaining ring.
JD 790 only came as diesel. It only used one ignition switch P/N AM876787
/ Ignition damaged by thief #19
I've replaced ignition switches on other vehicles, it's as easy as @zebrafive describes. The hardest part might be getting to the back side of the dash. That should just involve disassembling the dash until you have enough access.
Loosen the ring on the old switch before you take the dash apart.
/ Ignition damaged by thief #20
I had a 770 Great tractor.
Sorry, but not a great fan of letting your average mechanic touch anything electrical. Ugly crimp connectors and electrical tape. Just for starters, have you priced the switch from JD?
2022 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A61568)
2022 Peterbilt 567...
2 1/2 ft x 2 1/2 ft Metal Cage (A61166)
2 1/2 ft x 2 1/2...
2016 Ford Fusion AWD Sedan (A61569)
2016 Ford Fusion...
2024 CATERPILLAR 68" HYD 4IN1 BUCKET (A62129)
2024 CATERPILLAR...
2025 Mahindra 6075 4WD Cab Tractor - 71 HP, Loader Ready, Ag Tires (A63118)
2025 Mahindra 6075...
2020 Broyhill Load and Pack Articulated Solid Waste Handling Vehicle (A59228)
2020 Broyhill Load...
