Found this while mowing
   / Found this while mowing #11
There rake bar rotation is ground driven from the front wheels. To keep rake bar rotating while turning a corner front wheels are in fixed position and rear wheels caster. This is a late model has rubber tires. Dad's John Deere model was steel wheels.
Yes, when I was a kid, we had an old side delivery rake like that with the steel wheels.
I'm also thinking it might of also had a steel "tractor" seat (pan) on it, perhaps once pulled by horses?
   / Found this while mowing #12
Many years ago, when I used to do hay, that is very similar to the rake I used. After getting out of the livestock business, I couldn稚 sell it, so I hauled it to the local auction. Got a whole $65 for it. Never again.
Looks like a good winter restoration project, gotta find something to do in the cold and rain.
Another item we found, an old hay cutter.
   / Found this while mowing #14
My dad uses a rake just like that. Yours is in better condition than his.
   / Found this while mowing #15
It looks in good condition, do the tines rotate still? They handle the hay gentley and make good fluffy rows to finish drying the hay and are very agile to use.
   / Found this while mowing #16
We had the steel wheel version of this one and it raked a lot of hay behind our JD420 - I broke the rake gearing going too fast through a drain swale in the field @ 13 yrs old and my dad got the parts and the next day I tore it apart and fixed it - it was rusty but got it fixed.
Moral of the story - you break it you fix it was the way it worked on the farm.
If you find a baler your in business. ������
You joke about that, but dad is wondering what happened to the old square baler. He is thinking that it might still be in the back pasture, which we haven't even started working on clearing back there yet.
   / Found this while mowing #20
12' Pneumatic Trailer (A55973)
12' Pneumatic...
1997 international 4900 DT466E (A56435)
1997 international...
55-Gallon Drum of 50/50 Antifreeze Star Fire Pure Fleet Red Heavy Duty (UNOPENED) (A59076)
55-Gallon Drum of...
Toyota 7FGU35 8,000lb. Propane Forklift (A55973)
Toyota 7FGU35...
Hyster H90FT 8,000lb Diesel Forklift (A55973)
Hyster H90FT...
LOT: (2) Truck Brake Part #'s 66864B, (2) Truck Brake Part #'s RK8354709E2 (A59076)
LOT: (2) Truck...
