970 Case Hydraulic problems
/ 970 Case Hydraulic problems #1
hittleconstruction
Case 970 1970
Good after noon all!
Was looking for some more ideas to the problems I am having on this Case 970 tractor.
I purchased it with the problems and have not got to far solving the problems.
It is a 1970 Case 970 Diesel tractor Power Shift. It has a loader on it that runs from the two remotes on the rear.
Problems: Will not lift bucket most of the time no matter what the RPM. Bucket moves pretty well. The PTO works but I feel like it is only 70% power. I am running a older 12' swather, it binds up easy when I am mowing.
Here are the good points: Powersteers, Clutch, Powershift, Runs amazing,
Work I have done on it, New Dual remote valve, Pump, New filters, New screen on pickup tube, New fluid (Hy-tran only).
Thinking about taking out the Diverter next.
Any thoughts? Thanks
New thot of mine! I think I have 2 problems. First is the main cylinders on loader are blown out internally. I can unhook one side and the fluid will run for as long as I hold the lever. (5 gallon bucket then I stopped)
Second I may have weak clutches on the PTO. Works good until heavy load then stops.
2018 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A67147)
2018 KENWORTH T680...
2021 CATERPILLAR 349 EXCAVATOR (A65053)
2021 CATERPILLAR...
ELECTRIC POWER WASHER (A64278)
ELECTRIC POWER...
2023 WACKER NEUSON G70 TOWABLE GENERATOR (A63276)
2023 WACKER NEUSON...
1997 International 3800 School Bus (A64194)
1997 International...
2014 KAWASAKI KAF400B (A66091)
2014 KAWASAKI...
