TODAYS SEAT TIME
   / TODAYS SEAT TIME #10,001
Brush has probably put more woods tractors out of commission than anything else. I try to keep on my brushed out trails, but it doesn't always work out that way.
That is what I was trying to do, just clear my long overgrown [15+ yrs roads.:eek:
   / TODAYS SEAT TIME #10,002
A lot can grow up in 15 years, as you already know. ;)
ah, that huge bang and the wackety wackety wackety sound of something expensive coming apart...
The one's that you hear often cost you much less, as you know that something went wrong. That dangling transmission filter on the other hand...
   / TODAYS SEAT TIME #10,003
Spent about a day and a half cutting the second crop of hay. Will certainly be lower yield than the first cut but it's already sold so I'm hoping for lots.:laughing: In between cutting the lower/upper fields I hauled the tractor down to the SLC area and spread 36 yards of topsoil for my son who is putting in a new yard. That did not take long but it sure would have using a wheelbarrow.
   / TODAYS SEAT TIME #10,004
Nice cat fever . . . I think I mentioned one of my little sisters and hubby are looking strong in Idaho . . . they live in Portland now I feel sorry for them . . . ;)
   / TODAYS SEAT TIME #10,005
A little project running water and electric lines and a couple of new yard hydrants on my property. The little Yanmar done good.
   / TODAYS SEAT TIME #10,006
Today, the Big Plan is to work on the new tractor's home improvements. I'm adding an interior dividing wall to my pole barn, to isolate the bay where the tractor lives. This will include augering little footings for 5 upright timbers which anchor wall sections or support my I-beam with trolley and chain hoist for managing attachments. Thus I'll be putting my old auger on this tractor for the first time, and drilling with the electric clutch for the first time (I hope I do OK without having a slip clutch, but am pretty sure there can't be any living roots down there any more). I'll also take off the 800 lb ballast box for the first time since I filled it with concrete and steel, which should be fine, and at some point will want to put it back on, which might be pretty difficult. I wish the job I'm doing was already done, so I could handle heavy attachments with the equipment I'm erecting.
I did get to use the Front End Unloader yesterday when I came home with 6 bags of concrete mix in my station wagon. They're in my bucket now, and I intend to pull them out one by one wherever I need to mix.
   / TODAYS SEAT TIME #10,008
Just curious, how many acres there do you hay and how many of what kind of bales do you get out of it? I have a little 10 acre hayfield the guy up the street hays and gets about 15-20 bales a couple times a year. Your place just looks so expansive!! Looks nice too.
   / TODAYS SEAT TIME #10,009
Thursday evening I attempted to move some dirt for my shop project and the bucket would barely lift anything, thought it was just low on hydraulic fluid since it was leaking so I added a quart to the reservoir, still would barely lift anything so had to be belt, got one yesterday, it of course has a lower radiator hose going through it so drained the coolant and changed it. Loader worked great again, good enough to blow one of the hydraulic hoses coming out of the loader valve misting me and the whole right side of the rear of the tractor in UTF... Considering it is an outgoing hose and it didn't stop spraying until I shut the tractor down I think the valve is leaking internally...
   / TODAYS SEAT TIME #10,010
Project looking good! Nice job..
Thanks! I'm pretty proud of it. I started with a trencher, but the soil is way too rocky so I switched to the mini-ex. I didn't want to move that much dirt, but it went really quickly. I'm pleased with both the straightness and the level depth (18 inches for the electric).
2012 CATERPILLAR 336EL EXCAVATOR (A51242)
2012 CATERPILLAR...
2019 HINO 155 16FT BOX TRUCK (A50505)
2019 HINO 155 16FT...
19008 (A48082)
19008 (A48082)
2019 New Holland Workmaster 95 MFWD Compact Utility Tractor with 632TL Loader - Poultry Special (A52128)
2019 New Holland...
2004 Sterling L8500 4,000 Gallon T/A Water Truck (A50323)
2004 Sterling...
2007 Astec RT-360 Ride-On Trencher Backhoe (A50322)
2007 Astec RT-360...
