Needed: Adjustable side link for Kubota
/ Needed: Adjustable side link for Kubota #1
Pabco
Member
Meadow Vista, CA
Kubota B2650 / FEL LA534 / BH77 BH
I am looking to replace my manual factory (adjustable) side link with one of the crank type (see image below) on my Kubota B2650. They seem to make them for everything but Kubota. Appreciate any help locating one that will work with my application.
/ Needed: Adjustable side link for Kubota #2
There's currently a thread running in "Today's Posts" named "Opinions on best all around QH. Post #8 is by "Smokeydog". He posts a picture of his Kubota with the adjustable link you are looking for. Maybe PM him and ask about it?
I'd link you but for some reason my computer won't let me.
Ovrszd - thank you. I値l head there now. Appreciate it.
/ Needed: Adjustable side link for Kubota #4
Fairly certain that it is a factory Kubota option for your model.
/ Needed: Adjustable side link for Kubota #5
I've never saw one on the below Utility class Kubotas until I saw Smokeydog's pic.
Actually, when I think about it, I don't think I've saw one on their Utility class. My M9540 didn't offer it.
/ Needed: Adjustable side link for Kubota #7
I briefly looked into this when I traded my L3410 for an L4060. The 3410 crank seemed like it would work, but once I found out the Kubota pricing I immediately dropped the idea. I forget the actual price, but it was crazy expensive.
Hope you find something !
/ Needed: Adjustable side link for Kubota #8
Look in the Kubota parts section and it is there under options for a B2650. Maybe I'm wrong and parts show it, but it doesn't actually exist.
Shows to be $113 on the build your own tractor portion of the Kubota site. Need to get to the dealer installed options. I have no doubt that the $113 is in addition to the cost of the std adjustable link.
But it sure looks to me that a factory Kubota link is available similar to the OP's picture. ;)
MtnviewRanch - Thanks for the great info. I’ll check out and verify with our local dealer. Yes, Kubota isn’t afraid to charge at all, like when I pulled up a simple light switch for optional ROP lights. $57.00. Got to be available for $5.00 somewhere else...
/ Needed: Adjustable side link for Kubota #11
Both my M9's have them. Came from the factory that way...
/ Needed: Adjustable side link for Kubota #12
Yep, I've saw them on older models. What year are your tractors?
/ Needed: Adjustable side link for Kubota #13
I had the same problem looking for a leveling box for my Kubota L3901 and found a reference to Weaver's Compact Tractor Parts where I found one I could use with minor adaptions. Here's a picture of it
:Leveling Box.jpg
And here's a video I did on how I adapted it:
I have really enjoyed having it. Life is much easier with it! Good luck on your search for a solution!
:View attachment 617365
MPSmith - Thanks for your reply and the excellent video. After going around with Kubota parts (turns out you can order it when building a new tractor on their site) we found it. $119 for factory option. Should be in in a day or two. Will post images once installed. Cheers.:thumbsup:
/ Needed: Adjustable side link for Kubota #15
Thanks! Kubota sure doesn't make it easy to find, do they! I appreciate the info!
MPSmith60 - They sure don't. Part came in. Here's the deal. What the option is, is a replaceable ratchet center section (which you can swap out on your link). It seems very well made compared to others I've seen. $119. The Kubota parts manager brought out a factory link to show me the install. Simply unscrew the ends off your factory link and thread them onto this ratchet section. The ratchet section comes with a drilled and threaded zerk fitting hole, but no fitting. Go figure. Bonus, I paid for the part and he gave me a zerk fitting NC, as I went to leave he said here, take this factory link for free so you have a spare... Nice. Below are images of the parts and Kubota part number for the ratchet. The ratchet hand lifts up when needed and you simply pull it back and forth to ratchet it in or out depending on your needs. Enjoy.Kubota Adj Link Installed.jpgReplacement Adj Link.JPGKubota Ratchet Link.JPGKubota Adj Link Pt Num.JPGFac Link vs. Adj Link.JPG
/ Needed: Adjustable side link for Kubota #17
MPSmith60 - They sure don't. Part came in. Here's the deal. What the option is, is a replaceable ratchet center section (which you can swap out on your link). It seems very well made compared to others I've seen. $119. The Kubota parts manager brought out a factory link to show me the install. Simply unscrew the ends off your factory link and thread them onto this ratchet section. The ratchet section comes with a drilled and threaded zerk fitting hole, but no fitting. Go figure. Bonus, I paid for the part and he gave me a zerk fitting NC, as I went to leave he said here, take this factory link for free so you have a spare... Nice. Below are images of the parts and Kubota part number for the ratchet. The ratchet hand lifts up when needed and you simply pull it back and forth to ratchet it in or out depending on your needs. Enjoy.View attachment 617392View attachment 617396View attachment 617395View attachment 617394View attachment 617393
Thanks for this thread, and this info. Just ordered one of these from Messicks for my B7800.
Your welcome. Glad you could use the info. Cheers.
/ Needed: Adjustable side link for Kubota #19
Consider a telescoping side link. They're available from Kubota as well as after market.
UPDATE: Apparently Kubota (thru the guise of a zerk fitting on the ratchet) insert pins or a pin into one of the screw on leveling links. When you go to unscrew it, as it gets to the end the pin screws up the threads, so that you can't screw it into the (new) ratchet. Took the ratchet to my Kubota dealer and asked him how I was expected to use this "optional" ratchet with my old threaded link ends if taking them off screws up the threads (leaving you with two useless parts). He was unaware of it (on the B2650) because the parts diagram shows it as an "option" and does not show "pins" in the threaded ends on this model. He said he was going to make notes and contact Kubota re this. THEN, he went out in the yard and pulled off (see image) this assembly which came off another kubota (but I didn't get the model), and gave it to me for my ruined parts. He said that the setup he gave me bills out at like $200+ dollars. I was shocked. Came home put it on and it works like a champ. APPARENTLY, the original ratchet I bought was a replacement for the one he gave me (without pins on the threaded rods) so they can be used again. The ONLY other option would be to drill a whole opposite the zerk fitting, drill into the threaded section and drive out the pin that way, then you can reuse the threaded ends. I hope you can cancel your order, because it won't work as a direct replacement due to the stink'in pins Kubota inserts thru a zerk sized whole, as in, one way in, no way out... :-(
Oh, the proper one also has a clip welded on to hold the ratchet level in place. Sweet.
Year: 2011 Make: Chevrolet Model: Express Vehicle Type: Van Mileage: 118,735 Plate: Body Type: 3 (A59230)
Year: 2011 Make...
2019 Chevrolet Colorado Pickup Truck, VIN # 1GCGTCEN7K1209874 (A61165)
2019 Chevrolet...
2001 Chevrolet 2500 Service Truck (A63116)
2001 Chevrolet...
30 Yard Roll Off Dumpster (A61165)
30 Yard Roll Off...
UNUSED SDLANCH DIAMOND PLATED PLASTIC MATS (A62131)
UNUSED SDLANCH...
Rhino SE8 Rotary Cutter (A64047)
Rhino SE8 Rotary...
