Tired of cleaning Diesel soot of FEL (Kubota B2650)
/ Tired of cleaning Diesel soot of FEL (Kubota B2650) #11
Be happy you have soot versus the issues the Tier 4 final engines have. I'll take visible particulates (soot) over all the emissions junk anyday.
/ Tired of cleaning Diesel soot of FEL (Kubota B2650) #12
I had the same problem,$5.00 at the local muffler shop for the whole shebang! It does kick up some dust but that is easier to clean off than soot. I finally adjusted the exhaust outboard about 45 degrees.
/ Tired of cleaning Diesel soot of FEL (Kubota B2650) #15
very slick indeed
Very nice. Any (exhaust) problems while using backhoe?
/ Tired of cleaning Diesel soot of FEL (Kubota B2650) #17
Diesel - the air flow is behind the radiator grill and blows past it nicely.
As you know heat rises and may also warm your hydraulic fluid and hydro transmission.
Depending on where you live that could be a issue or maybe even a benefit in really cold areas.
Not saying its wrong or bad rather something to monitor to see if it has an effect or not.
/ Tired of cleaning Diesel soot of FEL (Kubota B2650) #18
Fixed mine too, now just have to watch for low limbs, the canopy is about the same height.
/ Tired of cleaning Diesel soot of FEL (Kubota B2650) #19
Interesting thread; I have never had any exhaust problem. Granted mine is tier 4, but look how it flows. Exhaust goes right in front of the tire and behind the FEL.
/ Tired of cleaning Diesel soot of FEL (Kubota B2650) #20
Try searching eBay for "silicone turbo hose coupler"
it will come up with all sorts of hoses, straight and bent, that can be used to extend the exhaust, yes, they can withstand the heat,,
Many cost less than buying the same thing in steel,
The BIG benefit is that if you hit something, the silicone will bend like rubber, and flip right back to original shape,,
Many people have ordered a size that is a little tight,, then you do not even need a clamp,, :thumbsup:
If I were doing it, I would probably end the extension with one of the reducers that would bell out at the end,,
The tractor would look like a kids Cummins powered Dodge pickup,,, :laughing:
2017 Peterbilt 320 T/A E-Z Pack 40Yd Front Loader Garbage Truck (A59230)
2017 Peterbilt 320...
Brent 420 Grain Cart (A61307)
Brent 420 Grain...
23" QUICK ATTACH EXCAVATOR BUCKET (A60429)
23" QUICK ATTACH...
2012 FORD F450 XL SUPER DUTY TRUCK (A59823)
2012 FORD F450 XL...
2012 Ford E-250 Cargo Van (A59230)
2012 Ford E-250...
John Deere 3025E (A53317)
John Deere 3025E...
