Which would you buy? (Help me spend my money)
/ Which would you buy? (Help me spend my money) #41
I'd rather buy a tractor made in Japan, than India, South Korea, or China, that's for sure!.. also, no Cast Steel frame!. formed Steel all the way!..
OP.... What do you mean by "harvesting rocks" for a retaining wall?
We tend to "grow" rocks where I live. You can't dig a shovel in the ground without hitting one. They vary in size from football to car size. In my woods, they are just sitting all over. I'd like to be able to go in, get them out, and use them to build up some retaining walls. This is one reason lift capacity (and wide tires with ballast) is important to me.
As an example, here are some pictures in my woods. IMG_20181013_141128.jpgIMG_20181013_140326.jpg
/ Which would you buy? (Help me spend my money) #43
If the OP is concerned about Hp and lift capacity - do like I did. I went with a Kubota M6040. NO problems - I can quite easily lift anything of any weight( on my property ) to any height with the grapple on my FEL. Why ponder & piss around - go big and don't regret it.
/ Which would you buy? (Help me spend my money) #44
Kind of my thought also.I have a L4240 HSTC with loader R1's and an impement in the back an still lifted the rear wheels.It has the 854 loader.I am in Northern NY also and have lots of rock and a great Kubota dealer.
/ Which would you buy? (Help me spend my money) #45
As an example, here are some pictures in my woods.View attachment 616305View attachment 616306
Understood.
Digging rocks out of the ground is tough work for a compact tractor loader. They really aren't designed for that kind of work and abuse.
Based on the other projected uses, you might also want to consider a skid steer, and a tracked one at that.
You can run a hydraulic snowblower in a heated cab. You can push a front grader box, land plane, Harley rake (etc) for road maintenance. Working on cleaning the trees would be better. And working with rocks and retaining walls would be better.
Just food for thought.
/ Which would you buy? (Help me spend my money) #46
If this is a popularity contest, Kubota wins.
If I'm deciding for you, get the Kubota.
Otherwise, get the one you like best.
Now see, wasn't that easy? :)
/ Which would you buy? (Help me spend my money) #47
Don't lump SK in with those others. The Koreans make the best cell phones and TV's in the world, and have for a while now. They are superb engineers.
Understood.
I think a tracked skid steer would be ideal, and have peripherally considered that, but the cost is just too prohibitive.
/ Which would you buy? (Help me spend my money) #49
See my in depth discussion above in post 29. Kubota loaders are weak, although lift higher, in comparison to others.
What I dont see in your post is the curves for the LS tractors (at pin and 500 mm forward). Did you find those as well? Just curious. It looks like you only have a curve for the Kubota?
Also I would restate your comment as “Kubota loaders in this class are weak”.
/ Which would you buy? (Help me spend my money) #50
That is exactly what I did. The M62 is incredibly compact for its capabilities.
/ Which would you buy? (Help me spend my money) #52
What's your max budget?
/ Which would you buy? (Help me spend my money) #53
I've owned both.
My previous tractor - John Deere 850 (made by Yanmar- Japan) and a Kioti DK 35 (made in South Korea)
Both were very good tractors.
If the Japan made JD was a better made or more reliable tractor than my Korean made Kioti DK you would have to show me where.
In the 18 years I have owned the Kioti, I certainly don't see it.
/ Which would you buy? (Help me spend my money) #54
Get a backhoe with whatever you go with. You need it for this task and you won’t regret it. Getting rocks like that out with an FEL won’t happen. And they are probably bigger than they appear on the surface. I also find it makes an excellent ballast.
Implements and all, 45k, including taxes. I'd really like to stay well below that, though. My plan for implements was forks, a box blade, snowblower, and grapple.
Kubota is the only one I've been able to get a curve for, so far.
/ Which would you buy? (Help me spend my money) #57
The 3560 loader IS anemic. If you step up to a 4060 you can get a much more capable loader.
/ Which would you buy? (Help me spend my money) #58
So some rough math to get an estimate at 500mm.
2718 lb at the pin. From the diagram in the LL4104 manual, the pin is roughly 5ft in front of the center of the front axle, so 2718 lb * 5 ft is 13590 lb*ft of torque at the front axle.
Now, 500mm is just under 20 in, so add that to 5 ft and you get 80 in, or 6 2/3 ft.
13590 lb*ft / 6 2/3 ft gives us 2038.5 lbs at 500mm from the pin.
Comparing that to the Kubota LA805 loader option on the L3560, the stouter of the two shown in the manual I found, at 1715 lbs at the pin and 1290 lbs at 500 mm forward.
All that being said, the Kubota lifts higher and all these numbers are at max height, so if you were to lower the Kubota to the height of the LS, it could be closer. I'd have to break out the old statics book to do that, and I'm not that interested haha! Hope I helped!
Manual page screen shots attached. Screenshot_20190808-194436.jpegScreenshot_20190808-194418.jpeg
Manual page screen shots attached. View attachment 616371View attachment 616372
See post 29. It's easy and straightforward to compare loader lift capacities at the pivot pins between the various models.
I guess my thought is, why step up to the L4060 and pay and extra $10k, instead of just getting an LS or TYM.
It seems most of the comments here are heavily skewed towards Kubota, probably with good reason. However, it takes a reasonably high degree of mental gymanstics for me to justify moving up to a larger tractor, and paying upwards of $40k, when a $30k LS or $26k TYM accomplishes the same thing.
Is a Kubota really worth paying 50%+ more?!?!?
Truck Mounted Carpet Cleaning Extraction Machine (A57454)
Truck Mounted...
2016 Dodge Grand Caravan SE Plus (A59231)
2016 Dodge Grand...
2023 FORD F-150 XL CREW CAB TRUCK (A59823)
2023 FORD F-150 XL...
BUNDLE OF 2"X8"-13'-19'L METAL FRAME WALL STUDS (A60432)
BUNDLE OF...
2003 LEEBOY L150 ASPHALT DISTRIBUTOR TRAILER (A52707)
2003 LEEBOY L150...
(INOP) KUBOTA ZD1211 ZERO TURN LAWN MOWER (A60430)
(INOP) KUBOTA...
