Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #9,171
I usually buy pro-level chainsaws. The Husqvarna 460 and 465 are their mid-level saws. I don't own one, but have used them on a number of occasions. If I were choosing between the Husqvarna 460 and the Echo CS-590, I'd take the Echo without hesitation (and I'm generally a Husqvarna fan). The CS-590 is closer to the Husky 555 or the old Husky 359 (both of which I'd favor over over the 460 or 465). That CS 680 is almost 1.5 pounds heavier than the Echo 590 or the Husky 460, and more than a pound heavier than the 465. That may not seem like much, but it adds up when you are hauling a saw around all day.
I searched some old literature I had and found the Echo CS-590 was rated at that time (5 years ago) at 3.89 HP. I found a few internet references listing that same HP rating. This puts it just about midway between the Husky 460 and 465, and for less money than either of them (and in my opinion, a little better construction). Plus the Echo comes with a 5 year warranty.
I would not get too hung up on minor differences in HP. HP does not tell the whole story. It's one indicator, but in big wood, Torque (and RPMs at peak torque) is a big factor. In the real world, how well you sharpen a chain will make a MUCH bigger difference in cutting time than the HP differences between any of these three saws.
In reality, any of these saws will do what Farmer2009 wants them to do: handle a 20" bar relatively easily, and get away with a 24" bar on occasion (perhaps with a bit of patience and a nicely sharpened chain). All of them are like night and day compared to the CS-400 you have been using.
Really, the only thing that would scare me off of the CS-590 would be if there were no good servicing dealers in your area. However, Echo has a well established dealer network. I'm sure they've got a couple, but you'd have to ask around if they are any good. I'd also recommend buying it from the dealer who will service it. You may save a couple bucks buying from a big box store, but you can;t beat the goodwill of a good dealer (plus, you are helping keep them in business).
   / Tractors and wood! Show your pics #9,173
Mowing around the the property today I decided to stop under a large black walnut just to appreciate it
   / Tractors and wood! Show your pics #9,174
Just as I got home from work today, son has his 6x6 in the garage and wants me to take a look, says he lost his breaks getting more wood, said he looked around and see's the rear axle is coming out with the break shoes showing on drivers side, on something this big breaks are a must.
So he says that he's been trying for two hr trying to get the wheels off and the wheel nuts wont budge after heating the crap out of one wheel nut. I go you going the right way they might be backwards threads, he goes didn't think of that after he did a number on my breaker bar with a 6' pipe, maybe frustration set in, so we did a close look and the threads are backwards or left handed.
I couldn't remember if the studs was left handed to or not so he heated the next wheel nut up, and with just one good right handed clock-wise yank the wheel nut spins off, I go there's your answer, the one he messed up had to wait till all the other nuts were off. Then I use my 40 year old home made red-neck square socket and with one good right hand snap they all game off, so the next time anyone messes with these two tear wheel stud nuts, make sure you go the right direction or left direction, depends what side your on, the passenger side looks right hand.
Now my son will be busy tomorrow trying figure out why that axle is sliding out........................
View attachment 615328 View attachment 615325 View attachment 615326 View attachment 615327
The axle unbolts from the hub on that center flange. Inside is a wheel bearing nut with a washer with tabs that get folded over the outer nut to lock it. Inside that is another nut that adjusts wheel bearing tension.
The nut(s) have came loose or one of the inner or outer wheel bearings have failed.
(Started Army career as a wheeled vehicle mechanic working on these)
Lenny
   / Tractors and wood! Show your pics #9,175
Just a little short wood/saw story...
I stopped at a coworker's house last week to help clean up a little storm damage. He had a decent maple branch come down just missing his kid's playset & his brand new shed, fell right between them. Since he lives on a quiet road in a small city, his yard is pretty small, in fact the tree was his neighbors. He has a small non running Poulan that never gets used, been sitting 6 years or so. I used my small Stihl MS211 to cut the branch up, we tossed the small branches back under the tree to add a new roof to the already there critter condo, & I took the maple logs, it was only 8" in diameter at the end. I also took his Poulan with me & spent time working on it Sunday. It started, but it would die when you even touched the trigger, or idled more than 5 seconds. I never had much faith in them, we jokingly say they got their name because you keep "Poulan & poulan, & poulan". The fuel filter had broken off the fuel line, the gas inside was definitely old, but the filter & carb were spotless, looked straight off the shelf. I reconnected the filter, looked over the other hoses, no visible holes or breaks, ran the plug over the wire wheel, & dumped in some fresh non-ethanol gas. Took quite a few pulls to get it to start, but she runs, sounds good at full throttle, no hesitation at all now. A lot of vibration even without cutting anything, but the handles & case are all hard plastic. I will sharpen it up, give it some test cuts to make sure it doesn't bog under load, then give it back to him. He told me to keep it, but I do already have 5 saws, so it will sit no matter what house it's at I guess! He can put it in his new shed, it is bright yellow & purple, nice shelf art I guess.
   / Tractors and wood! Show your pics #9,176
If he's not going to use it, you should empty the gas out and run it dry. That will increase the chance it's in working order when he pulls it out after the next storm
   / Tractors and wood! Show your pics #9,177
I split most of the last load I hauled in and brought in 2 more dead trees. IMG_7131.JPGIMG_7132.JPG
   / Tractors and wood! Show your pics #9,179
My son got his wheel bearings fixed on his 6x6 two days ago, today I get home from work and he's hard at it cleaning up the last of the cedar logs, suppose to have another load coming in two weeks. I wish I videoed just one more minute, just after I stopped and walked away, I hear him holler about something, he came in in the house for pizza and said he just broke a hose on the loader and fluid went everywhere, that would've been a great seen.
Army 6x6 loading logs, p2 - YouTube
   / Tractors and wood! Show your pics #9,180
That old rig works pretty good. He goes a good job not getting any dirt. Better to drop one once in a while than get a load of dirt.
Blown hose would make a good movie but you would probably have to kill the sound :laughing:
gg
PLEASE CHECK BACK!!! ITEMS BEING ADDED DAILY!!!! (A50775)
PLEASE CHECK...
2016 WITZCO RG-35 RGN LOWBOY TRAILER (A50459)
2016 WITZCO RG-35...
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A51222)
2019 KENWORTH T680...
2017 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2017 GENIE GTH-636...
1996 PETERBILT 357 35 TON WRECKER (A50505)
1996 PETERBILT 357...
2018 Bobcat T590 Two Speed Compact Track Loader Skid Steer (A50322)
2018 Bobcat T590...
