Solenoid chatter
/ Solenoid chatter #1
MillWeld
Gold Member
Durham NC
Ford 641
Recently I have been getting solenoid chatter on my Ford 641 tractor when I try to start it. (I converted it to a 12 volt system years ago.) I have found the problem to be apparently poor electrical contact between the + battery terminal and the battery cable. A black coating appears on the post and where it makes contact with the cable end. I scrape it off, reconnect and I can start the engine. This happened a year ago, again yesterday AND today. (I have not cleaned the post and cable end yet for today.) What are the cause(s) for this chatter?
/ Solenoid chatter #2
Low voltage because of corrosion causing resistant between battery post and cable..
Suggest scrupulous clean up of battery post and cable terminal (shine with scotch bright pad or sand paper), use baking soda wash to neutralize any acids on surfaces and coat contact areas with a oxidation preventive grease.... A oxidization preventative grease keeps oxygen and acids out of connection and prevents corrosion.........
I use this particular grease on all my batteries and never have any problems with corrosion on battery terminals....
Dale
/ Solenoid chatter #3
What he ^^^ said and if that doesn't cure it,cable might be rotted away inside cable cover. That call's for new cable.
/ Solenoid chatter
Alll right, guys. Pretty straight forward. I'm on it. Thx.
Bob
/ Solenoid chatter #5
Cause of the chatter is the drop out of your battery voltage. Senario goes like this: You turn the key/push the start button on an electrical system feeling full battery voltage. The starting solenoid has full voltage and energizes as expected. Once energized the engine wants a couple hundred amps from the battery to roll the starter. This amperage, when sucked through a bad connection causes a voltage drop across the bad connection part which is subtracted from the available voltage holding the starter energized.....like drop out voltage for 12v solenoids is like 9 volts.
Once the voltage across the solenoid coil drops below that level, the solenoid can't remain energized and it drops out opening the current feed to the starter.....whereupon the circuit voltage pops back up with zero current flowing to the starter and the solenoid re-energizes...etc. etc.
Same thing happens with a slightly charged battery and good electrical connections in the high current path.
20 Yard Roll Off Dumpster (A61165)
20 Yard Roll Off...
Four (4) R207782 John Deere Wheel Weights (A63116)
Four (4) R207782...
2005 Ford F-250 Utility Truck, VIN # 1FDSF20P95EA36131 (A61165)
2005 Ford F-250...
1988 KENWORTH T800 DUMP TRUCK (A58375)
1988 KENWORTH T800...
2014 BMW X1 S Drive 28I SUV (A61569)
2014 BMW X1 S...
UNUSED WOLVERINE SB84-84" ROCK BKT (A62131)
UNUSED WOLVERINE...
