BrokenTrack
- Joined
- Jan 13, 2018
- Messages
- 1,551
- Location
- Maine
- Tractor
- Tractors, Skidders, Bulldozers, Forestry Equipment
BrokenTrack: That's a lot of replacement/wear. What type of flail mower is that you're using? And, how long are your 'days', in which you average a loss of 7-10 shackles?
I use a Alamo Boom 6 foot mower, with 8 foot offset rear mower mowing ditches for municipalities. The tractor is a 4x4 120 HP John Deere, more for stability at full extension rather than for shear HP. The Alamo is designed for a 40 HP tractor, but on ditches it would be "flippy", so hence a bigger tractor. I average 12 hour days (no lunch or breaks as I subcontract out to the towns) and figure I mow about 34 acres per day.
It is pretty brutal conditions because the towns want to maintain "what they got" so I mow to the tree line. This means beating back as much trees as I can pony up too. But I hit other stuff too. In the last two weeks I have hit a chainsaw, a barb wire fence, (2) sections of sheep fence, a harrow, an elderly person's type of oxygen tank, and somehow managed to catch a rebar survey pin in a shackle and wind that up into the drum. None did the blades much good.
I also hit rocks. That is because the guys ditching do not like to put big rocks into their dump truck bodies so they push them out to the treeline...which is where I mow. Most of the time I can feel them as my mower skips along, but once and awhile, I get into a rock pretty hard.
Sometimes my shackles break, but about as often, the heavy grass/trees are pulling the cotter pins out and then the shackles come loose. Cost for knives, shackles, pins, and cotter pins is about $600 a year. Mowing season is July-August, or about 2000 acres. 2000 HARD acres.
PS: Those afraid of flipping tractors over, need not apply!
![IMG_1317[1].JPG IMG_1317[1].JPG](https://www.tractorbynet.com/forums/data/attachments/528/528014-1ebae2c0939bc2407b797533ce8e35f9.jpg)
![IMG_1318[1].JPG IMG_1318[1].JPG](https://www.tractorbynet.com/forums/data/attachments/528/528038-abeb0608ccd6558c72fe7dc5896f8370.jpg)
