Flail Mower Titan Flail mower
/ Titan Flail mower #121
Welding on something with bearings is fine with proper grounding. Put the ground clamp on the material being welded, not on the far side of the bearing. And make sure it's on good clean bare metal. Grind a clean spot as close as possible if need be. You only run into issues if the electricity is trying to flow across the bearing.
/ Titan Flail mower #122
I added some 4x1/4 angle to the back of my housing along with some gauge wheels, and I welded the bolt on lower lift arm support brackets because they keep coming loose. I added the gauge wheels because I am tired of the roller bearings digging into the dirt and/or my asphalt driveway when I am on side hills. I am hoping that the angle will keep it from twisting or bending. I am still trying to figure out the best way to reinforce the top link support, but I also built a top link "float bracket" to go between the mower and the top link (you can see it sitting on the right rear tractor tire in one of the pictures). This should take most of the stress off of the supports when mowing but not during transport, I also figured that it would be more necessary to let the back float since I have wheels further back. Please excuse the welds in these pictures, they are not as pretty as I would like because this is the first time that I have ever used a stick welder on a project instead of a MIG.
/ Titan Flail mower #123
Here are a couple of mods I've made to my Titan flail. One to make it iMatch compatible and one to reinforce the 3point tower before it fails.
/ Titan Flail mower #126
I bought a Titan 72" 3-Point Flail Mower with Hydraulic Side Shift. This was my first flail mower. First lesson learned, this is not a bush hog. I ruined the belts the first day. Second lesson learned the part number for the belt GB/T1154-97 on the parts list is bogus. I'm guessing all of the part numbers are bogus and have no meaning in the real world. I contacted Titan support it took them about a week, but they came up with a part number and a supplier. It turns out the belt is a Gates B39. If anyone has an EFG Flail Mower, they all appear to be the same, here is a supplier for the belts.
/ Titan Flail mower #127
My belts failed after a year. I contacted Titan and they told me they could only give me new belts if it was a warranty situation, which mine wasn't. The belts themselves have a part number on them, but it is a Chinese made belt. I searched high and low and the best I could do was find some in China they would sell me for $17 each and $150 shipping and up to 16 weeks delivery time. No thanks. But I found another company who made the same Chinese part number, and lo and behold they had an 'alternate part number' to an American Dayco belt. My local parts stores cross-referenced the Dayco to the Gates B39 mentioned, which works just fine. Titan's part numbers are just their own internal part numbers, useless to the customer.
/ Titan Flail mower #128
7.16 at RockAuto. But may want to find a kevlar belt cross ref.
/ Titan Flail mower #129
View attachment 610698View attachment 610699View attachment 610700
With the gauge wheels attached, can the rear roller be removed altogether when mowing? If so, does it improve mower performance?
/ Titan Flail mower #130
Glad to hear that. I'm still waiting on my Gates B39 to arrive. I was worried that I might have been too trusting in recommending them without first installing the belts.
/ Titan Flail mower #131
I hadn't thought about kevlar. Thanks, I'll keep that in mind next time I order.
/ Titan Flail mower #132
I've purchased several pieces from Titan, including this same flail mower, and have been pleased with all...... EXCEPT for the fact that Titan does not stock or even make available parts for their equipment. I dinged (pretty badly) most of my hammers cutting 5 acres of a rocky field. Titan will only replace these if it is a warranty issue (1 year from purchase). Obviously damage caused by trying to break rocks is not going to hold up as a warranty issue. I was pretty disappointed to learn this. Not being able to supply replacement wear parts for their equipment is a pretty poor business model by my way of thinking. If anyone knows of a good source for replacement hammers for these mowers I'd appreciate hearing from you. Thanks...... Gary
/ Titan Flail mower #135
I ordered a flail mower from Titan back in May. Showed up looking like it was dragged down the road behind a truck. Most of the hardware was missing. They sent me some of what I needed after contacting them. Still waiting on the rest. Its a cheap POS but it cuts my field.
/ Titan Flail mower #136
Hello and good evening Wook660,
I want to welcome you as the newest resident member from the Great State of Connecticut.
I am so sorry you went through all that. I wish Mathews was still selling small flail mowers as they were always of high build quality. Mine is 46+ years old.
/ Titan Flail mower #138
Oh geeze, I am so sorry to hear that. That is why I like to see buyers/TBN members purchase American or European flail mowers.
/ Titan Flail mower #139
Still waiting on parts from Titan, been 6 months now...
I was told Titan will not supply parts, other than the extremely limited selection they have on their website. They can do warranty repairs, but won't sell parts to the end user. It's too bad, because they do have access to all the parts.
Club Car DS Golf Cart (A64047)
Club Car DS Golf...
2008 DOOSAN G25 GENERATOR (A58216)
2008 DOOSAN G25...
2015 DODGE DURANGO RT SUV (A59575)
2015 DODGE DURANGO...
UNUSED INDUSTRIAS AMERICA C10 10' FEEDER TROUGH (A60430)
UNUSED INDUSTRIAS...
2 new 10'' Pallet fork extensions (A61567)
2 new 10'' Pallet...
2014 Nissan Quest Van (A61574)
2014 Nissan Quest...
