MY bush hall will not lift by using my lifthandle on my tractor.
/ MY bush hall will not lift by using my lifthandle on my tractor. #1
DJP
Jackson,MS
Mahindra,4500
I have a Mahindra 4500 two wheel drive, my bush hall lift handle appear to be locked. I cannot not move it up or down, using my hand. If I take something and bit it back than the bush hall will lift. What is wrong with my lift handle, while it appear stuck, how to get it loose, and lifting my bush hall again.:mad:
/ MY bush hall will not lift by using my lifthandle on my tractor. #2
Have you tried greasing your zerk fittings? Seriously when I cant lift my implements in back I grease the fittings back there and the they lift up and down when I use my lift handle. Just my 2 cents. I have all the filters for your 4500 for sale of you need them. I ordered them from someone on Amazon and they wouldn't take them back even though I never used them. They are brand new in the box if you need to do an oil change or whatever. I have 6 filters for you 4500. Let me know.
Owen Collier
/ MY bush hall will not lift by using my lifthandle on my tractor. #3
Your linkage is locked up. Look at it with a strong light so you can see all pivot points. Douse them with penetrant, and work the handle up and down until it's free.
On the other side of my seat the left side is two handles, the lower handle is the handle that puts the bush hall cutting blade in gear to start turning and cutting. Also on the left side of my seat is another handle that goes across the bottom of the seat. Can someone tell me what this handle is for. Could I have may have moved the handle in the wrong position and that is why my bush hall is not lifting. The handle is as of now position to the far left. Again what is the handle for?????????????????????
Thanks for the reply ACHINGBACK: Where on the tractor is the linkage that maybe locked up??? Where are the pivot points, that you are talking about???? Can I use a good penetrating oil to loosen the linkage?????
/ MY bush hall will not lift by using my lifthandle on my tractor. #6
Does your tractor have rear remotes? You might have your hydraulic flow going to them??
/ MY bush hall will not lift by using my lifthandle on my tractor. #7
Is "bush hall" possibly a typo?
/ MY bush hall will not lift by using my lifthandle on my tractor. #9
I had this issue with my 4025, I had to keep spraying the levers with penetrating lube. After a few days of doing this it broke free, and operated good as new.
/ MY bush hall will not lift by using my lifthandle on my tractor. #10
Sell the tractor!
Seriously. A bush hall in the wrong hands is very dangerous.
/ MY bush hall will not lift by using my lifthandle on my tractor. #11
Based on OP's posts history, I think a push mower would be less challenging.
1998 CHEVEROLET 1500 LONG BED PICKUP TRUCK (A59905)
1998 CHEVEROLET...
2025 Pabreak Hydraulic Brush Cutter Skid Steer Attachment (A61567)
2025 Pabreak...
2007 FORD F-150 XL TRITON (A58214)
2007 FORD F-150 XL...
2024 MAC TNAR39FR540 40FT T/A  FRAMELESS END DUMP TRAILER (A59906)
2024 MAC...
2018 INTERNATIONAL 26' BOX TRUCK (A59906)
2018 INTERNATIONAL...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55851)
iDrive TDS-2010H...
