Over Running Clutch for Tiller?
/ Over Running Clutch for Tiller? #1
Diggin It
Super Star Member
I'm thinking, I'm thinking!
LS MT125 TLBM
TS has this over running clutch thing that mounts to the PTO shaft for about $70 or so, sometimes less on sale. Reviews seem mixed. Guessing there are probably other versions as well.
Overall length is about 3-4" inches which might make up the difference in PTO if I wanted to add one of those 3PT quick frame contraptions also. That's another $80 or so at various places.
Current set up is PTO shaft direct between tractor and tiller, no clutch unless there's one inside the tiller.
Would I be gaining anything useful by spending that $150 or so?
/ Over Running Clutch for Tiller? #2
A tiller runs really slow, usually around 230 to 250 RPMs. Doesn't create enough inertia like a mower does, so it doesn't really need a Over running clutch. I would use either a Clutch on the PTO shaft or a fuse type PTO shaft though, in case you hit something hard or the tiller grabs a hidden root or something.
The Over running clutch is good for a mower. It will save your PTO brake once you shut the PTO off.
Well, fooled me anyways. There IS a slip clutch on the tiller end of the shaft under the shroud.
/ Over Running Clutch for Tiller? #5
My tiller has a slip clutch in-case it hits something buried. An over running would be when you have a high inertia implement that you're spinning.
/ Over Running Clutch for Tiller? #6
Yeah, you should loosen it, slip it (break rust), re-tighten it, yearly.
Do or die advice, folks! For me, it's an annual "4th of July chore" along with resetting the air pressure in my well tank. (Well-X-Trol bladder, WX-2)
Over-running clutch would let one 'walk' a tiller on it's tines over very soft ground vs sink in with the weight of the implement then NOT borne by the rear wheels. A rare situation, but possible. :cool2:
IMO it'd be a sly way to extend a PTO shaft, say for Pat's Easy Change. (Too good to abbreviate!!) Try to imagine any instance where it would be a detriment to an op or attachment. :confused: IMO, such is a necessity in a complete 'toolbox' of "Tractor tackle".
First excuse to get one, I'll be there. Expect admonition upon those who wouldn't invest 'just in case' anyway.
PS: just got carried away one I started editing, but "Tools is Tools", and IMO an o/running clutch is one.
/ Over Running Clutch for Tiller? #7
They sell pto shaft extensions for much less if you are just looking for more lenght
/ Over Running Clutch for Tiller? #8
Not from me. I look at this the same way as insurance. Hopefully you'll never need it, but it only takes once to wish you did have it.
/ Over Running Clutch for Tiller? #9
Any time you extend your pto shaft, you are just asking to have more pto problems on down the road, like seals and bearings...
SR
/ Over Running Clutch for Tiller? #10
or put more stress on the PTO drive at the tractor, i will second SR on that one, not worth the expense, they make things the way they make them for a reason, you can get by for a while but it will catch up to you in the long run
/ Over Running Clutch for Tiller? #11
USING the PTO puts stress on it. Should we only use it for barbecue then? There's a difference between 'might break' and what tractor is made to do.
I guess the need to be close to a dealer is for ham-fisted guys that break tools. I haven't yet, but give me another 13 years of operating and I might bust a tractor. "none out of five" broke so far. :rolleyes:
"Paranoia strikes deep.." S. Stills
2010 Ford F-350 Crew Cab Diesel (A62679)
2010 Ford F-350...
2021 CATERPILLAR 326 LONG REACH EXCAVATOR (A65053)
2021 CATERPILLAR...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
2004 International 8600 Tender Truck (A63688)
2004 International...
New/Unused Landhonor 21ft x 13ft Metal Carport (A65583)
New/Unused...
John Deere (A64126)
John Deere (A64126)
