Window needed New Holland TN 75 DA
/ Window needed New Holland TN 75 DA #1
Hi where could I buy a reasonable priced left-hand lower window if youæ±*e seated in the tractor .Or could you recommend who installs windows in tractors. 2005 TN 75 DA
/ Window needed New Holland TN 75 DA #2
Try Broken Tractor New, Used, and Rebuilt Parts www.
/ Window needed New Holland TN 75 DA #3
I have seen a few that used lexan cut to fit,
you can get a 12 x 20 piece for around $20 and shape to fit.
/ Window needed New Holland TN 75 DA #4
try a Glazier, they'll make you one out of safety glass, which won't break into large dangerous shards like regular glass or Lexan will. there is stretched Lexan, which breaks into small pieces, IF you can find it.. but Lexan scratches easily, and will need to be replaced often because of that..
/ Window needed New Holland TN 75 DA #5
I am also going to say to try your local window repair guy. Don't confuse hi with your local independent hardware store who does windows and screens, they probably won't be as helpful. i guess I'm lucky to have such not far away, but they still do exist. Explain what you want and they should be able to help.
Yes I tried to local guys he痴 trying to tell me there is slight curvature to it I don稚 feel like spending 350 to 400 some dollars to put a 1 x 2 window in
Thanks for the heads up
That痴 an Internet site I知 in northeast PA
. Yep I thought about going that route I have cardboard in there now it痴 noisy dirty I just don稚 have three $50-$400 to put a silly little window in
/ Window needed New Holland TN 75 DA #11
We have a small guy around that does that kind of thing. But it helps to have a pattern for him to go by. There is generally laminated glass like a car windsheild and tempered. You can't cut tempered. You need to cut it before it's tempered. Glass places will send it out for you, but in the end it costs more than laminated which can be cut to size.
1992 John Deere 210C 58HP Loader Utility Tractor with Box Blade (A61572)
1992 John Deere...
159118 (A60430)
159118 (A60430)
12,000 GAL FLAT BOTTOM ALUMINUM STORAGE TANK (A63291)
12,000 GAL FLAT...
Unverferth 330 (A64119)
Unverferth 330...
2000 Bobcat 763 (A60462)
2000 Bobcat 763...
2014 Ford Escape SUV (A61574)
2014 Ford Escape...
