Dust control
/ Dust control #1
Tomtint
Elite Member
Boston
L3700SU
I know there are probably a hundred threads on this topic, but this can be 101. ..Anyway..I have about 1000 feet of dusty nasty road. I also have a 12 volt sprayer .. I think 25/30 gallon capacity..had it for years but have never used it.. I'm thinking about putting it in the back of. The RTV and setting up a boom ..probably buying it from Tractor Supply .. and spraying used peanut oil .. as I have a free supply of 25/30 gallons a week. I'm wondering if it would need to be thinned so it won't clog the spray heads... I will most definitely strain it as it's put into the tank first.
/ Dust control #2
I just wonder - will the peanut oil attract rodents or other unwanted animals.
/ Dust control
We already have virtually every critter in the world out here now... can't imagine any new species that we have not seen before
/ Dust control #4
Ya - never thought of that. I could sure use something like that. The one muddy section on my mile long driveway turns from mud to dust. It's only about 80 feet, but Lordy - what a dust storm it creates.
I'll be following to see how it turns out.
/ Dust control #7
I would do some research before using peanut oil; being a vegetable derived organic, it could cause some undesirable effects if bacteria, sunshine, etc. cause it to degrade. I found this:
Top Ten Dust Control Techniques List
/ Dust control
Got the tank in and hooked up. Tested it with just water to make sure there were no leaks. Everything but the drain is good. I think I need to add some tape to the threads of the drain cap as it has a slow drip. Going to first use it with tenacity herbicide on my lawn to kill off the bent grass ...then onto the dust.
/ Dust control #9
Good luck with the peanut oil.
In the old days used motor oil was commonly used for dust control.
actually any type of oil did a good job of that.
Also calcium chloride works good a bit corrosive to vehicles, it will pull the moisture right out of the air to keep it's self damp.
/ Dust control
I have a salt spreader that I use in the winter.. could probably get put it in the bed of the dump and drop a ton of salt on the road.
/ Dust control #11
I have tried salt, it didn't work that well.
The last time I spread calcium i used a little spreader as it would be hard to 2-3 bags of calcium go far in a sander;
my lawn mower tractor transmission get weak real fast when it's hot out so all use it for is trimming so when I put some calcium down last week I had a bit of overkill
/ Dust control #12
Shortly after spraying with peanut oil for dust control.
Bruce
/ Dust control #15
This is what my farmer/neighbor uses.
He isn’t happy with the results and DOESN’T recommend it.
You’re welcome for the NON help. Lol
/ Dust control #16
The EPA calls this fugitive dust control. Google will find you many documents on this. Mostly I've seen water trucks spray the roads on industrial sites.
