LS Tractor & New Holland model equivalents
   / LS Tractor & New Holland model equivalents #21
It would be interesting to know if they are using the new LS engine in other brands.
Yes, NH is using the LS engine in new models and the Shibaura engines in the older models. I didn't compare but think Massey Ferguson is too. My neighbors MF has the same engine as my LS.
Comparison Results | NHAG
   / LS Tractor & New Holland model equivalents #22
Can you tell me if the New Holland TC34DA is made by LS?
   / LS Tractor & New Holland model equivalents #24
Can you tell me where to look?
   / LS Tractor & New Holland model equivalents #25
I've seen tags on the front frame (left side of tractor) behind the left wheel and on the lower rear of the ROPS. Should say something like Mfg by LS Mtron. Other New Holland tractors are made by NH and division of CNH Industrial. You can also check specs on NH tractors on tractordata.com. Most of the Boomer series will show the engine by LS Mtron, a dead giveaway it was built by LS. Older NH tractors with Shibaura or Mitsubishi engines were built by LS also.
   / LS Tractor & New Holland model equivalents #26
The New Holland TC34DA tractor was made by Shibaura Tractor Company in Japan. I used to own one of those; good tractor. This was before New Holland moved its compact tractor line to LS.
UNUSED PABREAK TCR380-84" HYD TRENCHER (A58376)
UNUSED PABREAK...
2013 FREIGHTLINER CASCADIA (A58214)
2013 FREIGHTLINER...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
New/Unused 20 Ton Hydraulic Jack (A57454)
New/Unused 20 Ton...
New/Unused CFG Industrial MH12RX Mini Excavator (A57453)
New/Unused CFG...
2018 CATERPILLAR 289D SKID STEER (A52709)
2018 CATERPILLAR...
