Setting a turning plow
/ Setting a turning plow #1
challengertn
Southern middle Tennessee
MF 135 soon to be Kubota
I'm ashamed to say how long I've been doing this but I have a 135 MF with one of the older ferguson 2 bottom plows that just doesn't like to follow very well. It tries to run too far inland a lot of the time. I've tried more or less point and leveling and it still doesn't like to do right. Any ideas?
/ Setting a turning plow #2
Might be able to help, but I didn't understand what it was doing wrong, nor what you tried to fix it.
Care to rehash that again, and see if we can come to some conclusive help?
inland?
point and levelling?
There have been some pretty good descriptions in the past year, and a search and 'read' of the threads that have to do with 'plow' and 'moldboard' might bring them up for you.
Keep talkin' and we'll keep listen'n. /forums/images/graemlins/wink.gif
/ Setting a turning plow #3
Maybe I can help, I am an oldtimer. The tractor has to be narrowed in and I guess you already know that. The plow point needs to be in fairly good shape to do good also. Just make the frist round with the plow working so that the last plow will make a furrow for the right wheel to follow in and then on the next round you will have to play with the third arm and the up and down part of the right lift arm. Get it to track well, that is not to leave an unplowed place between the front plow and the plowed ground and then get it level. I can make it level as a concrete floor. Setting a breaking plow is an art and no one can really tell you how but you will never forget once you get the hang of it. A properly set turning plow pull easy, an improperly set turning plow will pull a tracotr to death and still do awful bad looking work. I personally like my ground turned and disked better than I like tilled ground. Good luck and have fun with your turning plow my friend...teddy
/ Setting a turning plow #4
The easiest way to tell someone that has never done it before is as follows. Get a 6" block of wood. Drive the right rear tire upon the block. Let the plow down to the ground. Adjust the plow to where both plows are flat on the ground. Now go the ground that you want to plow. Start plowing. You can then check to see if the plow is cutting all of ground between the second trip and first trip. If it is not, you will need to adjust the right wheel width. This part is done with the right tires in the furrow. It may still need to be fine tuned, but this will get you close.
/ Setting a turning plow #5
JerryG
Are you sure that isn't the left rear up on the 6" block, simulating the right in the furrow? I use the procedure you describe but am sure I raise the left wheel.
In addition, some plows have an adjustable cross beam that the lift arms connect to, that can be rotated to 'steer' the plow in the direction you want it pulled. My one bottom Dearborn plow has that, and it makes it easy to adjust. Some recent cheaper plows don't have this, but I suspect this person's plow does.
Beenthere, I'm sorry to be so vague about what I was saying. In giving the plow more or less point I was referring to adjusting the third link to make the plow run more or less on point and by leveling I was referring to raising or lowering the adjustable right arm to make the plow run more or less level after it is in the ground and the tractor tires are in the furrow. JerryG, I finally tried the block method last year and it seemed to help but I still have a problem. Teddydo, I'm almost 50 years old and I haven't farmed for a living since helping my father as a teen years ago. I only plow mostly gardens now and that makes it harder for me to set a plow. I agree that it is an art. My father was a master at it although it would take him a pretty good while to get it to his satisfaction when I took over it was if there was almost no strain on the tractor. It was ironic because he really cared nothing about farming and I would love to be able to do it for a living and I can't set a plow for squat. I will say that it helped when there was several acres to plow instead of just gardens. I've never taken into account the wheel width but I believe they are narrowed up all the way. I have toyed with the part of the plow that connects to the two main arms because it can be loosened and slid side to side. I don't think this is the problem but have you ever heard of the plow not matching the tractor in height and causing it to pull hard? I had a neighbor who bought a 180 MF that is a higher clearance tractor and they had sold him a plow that matched up to a 175 MF. He used it for years until another dealer informed him of the mistake. He bought the correct plow and was able to pull a larger plow. I don't think this is my problem but just food for thought. Would a longer landside or slide whatever you call it on the rear bottom help any?
Beenthere, you are correct, it does have the adjustable beam and it very well could be a Dearborn plow.
/ Setting a turning plow #8
If your plow is a Dearbourn and looks like this I can pass to you the original set up instructions. If you would like them send me a PM with your email address and I'll shoot the works over to you. It's a rather large file.
/ Setting a turning plow #9
Doesn'tthis allow you to move the plow over so the right tractor tires fit in the furrow?
Egon
Well due to my ignorance the only thing I could think it might be used for was in the leveling of the plow due to each end being offset up or down from center. If I understand these guys right those offsets should be more towards front or back to control the direction the plow travels in. I slid the bar to the side once but the front plow failed to take enough ground.
/ Setting a turning plow #11
<font color="blue">Are you sure that isn't the left rear up on the 6" block, simulating the right in the furrow? I use the procedure you describe but am sure I raise the left wheel.</font>
It is the left side tire./forums/images/graemlins/crazy.gif It’s been a bad week already and it’s not over yet. /forums/images/graemlins/frown.gif The tractor has to tilt to the right. The reason that I always tell everybody to use a block is because if they don't do it this way first they will think that there is no way that it could be the right amount of tilt. I just crank my arm adjustment to where the points are off the ground a good amount when it is sitting on the ground. I have done it enough that I know where to stop the crank at.
<font color="blue">In addition, some plows have an adjustable cross beam that the lift arms connect to, that can be rotated to 'steer' the plow in the direction you want it pulled.</font>
Yes, some do. Mostly older plows with more than one bottom had that adjustment. I don’t see how the new plows without this adjustment can be made to work right. I know that most older Massey and John Deer plows can be set up to do a good job and pull easy. I have a MF model 66, three bottom that works fantastic and pulls very easy. A good 3 bottom plow that is setup right is easier to pull than a poorly setup and built 2 bottom.
<font color="blue">I've never taken into account the wheel width but I believe they are narrowed up all the way.</font>
The point of the front bottom needs to cut into the previous furrow. To make it do this, you need to have the right wheel set at the right distance out.
<font color="blue"> Would a longer landside or slide whatever you call it on the rear bottom help any? </font>
I don’t see how it would help any, but it might.
" The point of the front bottom needs to cut into the previous furrow"
Are you saying the back end of the front point needs to stick out into the furrow?
/ Setting a turning plow #13
Plowing right, no part of the plow bottom should be in the path of the old furrow it is covering, IMO. Leaving a bit of attached roots at the furrow's left edge will aid in 'turning' or rolling the new cut over into the furrow.
Important to plowing with the 3pt is for the draft control to be working right, and for the top arm to be hooked in the right linkage for the draft control system to function. I'm not remembering what your tractor has for draft control, but it may be having some effect on controlling the depth of the 2-bottom plow.
/ Setting a turning plow #14
<font color="blue">Are you saying the back end of the front point needs to stick out into the furrow?</font>
No, the front tip of the front plow bottom.
/ Setting a turning plow #15
I didn't mean to say for the plow to be in furrow, but for the point to cut the edge of the furrow.
<font color="blue"> IMO. Leaving a bit of attached roots at the furrow's left edge will aid in 'turning' or rolling the new cut over into the furrow. </font>
In some soils with certain plows, that might be necessary. In most soils, I prefer to cut it out without going into the furrow. I am sure there are many different ways that people set up plows. Even ground speed makes a difference with where I like the plow set.
I think that there is a problem with the draft because the lift is constant manual operation trying to keep it at the right depth. I think the adjustable front bar could be the culprit on the taking of too much land because it is straight up and down right now. The tractor also steers hard due to the pull of the plow. The plow no longer has the rolling landside if that is the correct term. Several years ago it was retro fitted with newer bottoms and coulters due to the price and availability of the fitted points. It is a 2 12" bottom plow with 14" points. JerryG, I know I'm just misunderstanding you because the way I read it you would have the front plow traveling out in the open furrow made on the previous pass not turning anything over.
JerryG, I just read your last post and I understand now. It's getting late so I'm going to bed. I'll be back tomorrow. Thanks, Gentlemen
/ Setting a turning plow #18
Just a though I use. If you are on level ground the plow should be level side to side and front to back while in the ground.
I use a 6" block to but also the front tire to. This way your tractor is level front to back and yout top link adjustment will be closer to right.
Just shareing how I do it, This can get confussing.
/ Setting a turning plow #19
I tell you these turning plows are great tools. When used with expertise you can choose to build a terrace waist deep if you like. When set right and the right speed you can turn ground and do little disking, in some ground just harrow after turning. It will simply take a little effort and time to learn what you want but it will be worth the effort. I prefer turning over chiesling groung anytime, you can hide corn stalks easy. Sometimes I disk lightly before turning. Some around here have big tractors with small turning plows and pull them thruogh the ground just any way but you can tell by looking at the workk they aren't set properly. I am glad this topic got started........teddy /forums/images/graemlins/laugh.gif
Once again I want to thank all of you who answered this thread. I must admit when I posted this question on this site I was skeptical about what kind of answers I would get on a compact utility tractor site. I didn't know how many people still used a turning plow and especially with the smaller tractors. You've proven that there was nothing to worry about except honing my own skills which I can't wait to try when this bad weather subsides. I hope all of you have a very Merry Christmas and next year will be a good one for you.
2016 Ford F-550 4x4 Mason Dump Truck (A61568)
2016 Ford F-550...
UNUSED SDLANCH SDLFP30 EELCTRIC PALLET JACK (A62131)
UNUSED SDLANCH...
Tandem Axle Rear Truck Frame (A61568)
Tandem Axle Rear...
UNUSED WOLVERINE SB66-66" ROCK BKT (A62131)
UNUSED WOLVERINE...
2023 John Deere 8R 280 Tractor (A63109)
2023 John Deere 8R...
2024 GD Yatian LY05A Model T Replica Electric Cart (A61569)
2024 GD Yatian...
