   / Harbor Freight Tools that don't suck #11,321
Yes I file or belt sand the angle finer not a fan of grinder to work on a cutting tool. As far as how much to take off? That is kind of hard to tell you over the net. I am 57 , l was taught to sharpen very young by my Hillbilly dad and uncles. I free hand sharpen. And like knives there are a lot variables. I would say that if you bevel back 3/8th to a 1/2 on the harbor freight axes you would get a decent edge. On a double bit axe with good steel I may bevel the cheeks back close to an inch, double bits are felling axes pure and simple on a rough use hatchet of questionable steel I may only bevel back a 1/4 inch same with a tool for splitting.
This were the Harbor freight hatchets are great they are cheap enough to practice on . Look at the handles close before you buy it , go slow and cool the metal often .
I have reprofiled axes with a file before too. The U.S.A. made Vaughan hatchets are as good as they get , if you can reprofile and sharpen but come with virtually no edge they are 1085 high carbon steel.
Thanks, great info!
I have two felling axes and a hatchet handed down from a great-uncle's farm in NC. They are easily more than 100 ys/old. The handles have gotten so loose over the years, I have to soak the heads in a bucket of water before use. I have another hatchet and a half-axe that are 60 ys/old.
I've thought about rehandling the felling axes, but maybe that would just ruin the antiquity!
Guess I shouldn't keep using them to cut tree roots, either. :eek:
Next time I'm at HF, I'll pick up their fiberglass-handled (felling?) axe. :thumbsup:
3.5 lbs. Fiberglass Axe
   / Harbor Freight Tools that don't suck #11,323
The negative reviews on that one aren't complimentary. Two pages of 'head fell off'.
And I've been using one for 10+ years of root chopping with no problems. :)
Bruce
   / Harbor Freight Tools that don't suck #11,324
Bruce
Sounds like that is one of the rare cases where the extended warranty would be worth it. Just in case it takes a couple of returns before finding a good one, worth keeping.
   / Harbor Freight Tools that don't suck #11,325
   / Harbor Freight Tools that don't suck #11,326
First off even with name brand axes and hatchet I want to look at it before I buy it . I looked at a rack of Kobalt hatchets at Lowes once . 3 of the 4 the heads weren't straight with handle and the 4th the grain orientation of the handle was terrible . House handles is the only place I will buy axe handles on line . As someone who has made their living with tools I find at least half of bad reviews on tools are user error . There are reviews on the 3.5 axe calling it sharp :laughing:
here is a fun project with a harbor freight axe I looked at 4 axes on the rack and only one was acceptable . this is what I started with
2.25 lb fireman's hatchet
after sanding and reshaping the handle reprofiling the edge and cutting the spike off and smoothing it out
   / Harbor Freight Tools that don't suck #11,327
JB Weld it instead of Mig perhaps.
   / Harbor Freight Tools that don't suck #11,328
Bar magnet - HF's sometimes-free 'Magnetic Tool Holder' - cut down and mounted on the HF Qhitch. It's about 3/4 its original length and seems slightly less strong, but more than sufficient for holding clevises, pins, clips. Welding wasn't a problem. Those linked comments mentioned the arc being pulled aside by magnetism, but I didn't notice that.
Recommended!
   / Harbor Freight Tools that don't suck #11,329
Recommended!
That's a good idea and opens up to lots of similar ideas. Thanks.
   / Harbor Freight Tools that don't suck #11,330
Just do it! they aren't magic but they are worlds better than doing without.
True that- we bought ours in 2011, when they were on sale- with the coupon off too, and it continues to serve us without any issues or trouble, despite my beating the absolute H-E-double hockey sticks out of it.
2021 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A55973)
2021 Allmand Bros...
TANK MANIFOLD (A58214)
2007 MACK GRANITE CV713 DUMP TRUCK (A60430)
2007 MACK GRANITE...
2020 CATERPILLAR 336 EXCAVATOR (A60429)
2020 CATERPILLAR...
2019 Grove TMS500-2 40 Ton Hydraulic Truck Crane (A60460)
2019 Grove...
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2016 Ford F-150...
