   / Harbor Freight Tools that don't suck #11,291
I bought the 60 piece Pittsburgh SAE/Metric Tap & Die set Item 35407. This afternoon I threaded over 16 inches of 3/8" mild steel rod. The die is still cutting well. Tap Magic is the lubricant I used.
   / Harbor Freight Tools that don't suck #11,293
Amazon has quite a few led shop lights, many of them "linkable". Their way of saying they can plug into each other.
They have a 4-pack for about $80. I will most likely purchase those in the near future. I believe the lumen output is about 4800....not bad for just a few watts....42 per fixture compared to a T8 fixture which is closer to 100 watts.
   / Harbor Freight Tools that don't suck #11,294
   / Harbor Freight Tools that don't suck #11,296
   / Harbor Freight Tools that don't suck #11,297
Are those LED bulbs easily found in the marketplace or are they unique to HF?
Claimed 30,000 hours life, that's 10 years in an industrial shop that's open six days a week, and years longer in the typical HF customer's home shop. I think it's a throwaway fixture.
   / Harbor Freight Tools that don't suck #11,298
As California mentions none I've seen are not repairable. Buy a new whole light.
There are LED bulbs that you buy to convert your existing fixtures but that's a whole different thread.... :thumbsup:
   / Harbor Freight Tools that don't suck #11,299
Will the hooks on yours require cat 3 to cat 1 bushings? The HF photo seems to show their original version that took cat 2 to cat 1.
I haven't even taken it out of my truck yet but, plan to give it a look over this afternoon and I'll report back. I'll need the bushings on a couple of implements and rest are Cat 1 / Cat 2 hitches. Found some pretty good prices, for the bushings on eBay.
   / Harbor Freight Tools that don't suck #11,300
Cold weather has little effect on led lights.
I'm not sure about that. I've had electricians here tell me that some of the cheaper ones have problems starting up the light in the cold. But most will start ok until it gets down to around 0 F degrees. Once it gets to -40 F, some of them have problems (but so do fluorescent lights).
I guess it depends on what you mean by "cold"?
TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
TOOTHED BUCKET FOR...
2017 Chevrolet Express 2500 Cargo Van (A59230)
2017 Chevrolet...
14C SCRAPER (A58214)
INTERNATIONAL FLAT BED TRUCK (A52707)
INTERNATIONAL FLAT...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2022 CAT 289D3 (A60462)
2022 CAT 289D3...
