What did you do on or to your LS Tractor today?
   / What did you do on or to your LS Tractor today? #641
I got the light bars on tractor then finished the portable goat house I will take photos tomorrow of me moving the house into there current area had some supervision as well soon as I put on new lights that basically lit up a acre of land around tractor lol seen two armadillos panicked to find a place that was dark lol
   / What did you do on or to your LS Tractor today? #642
Five different pigs in about hour and a half and non too bothered by me mowing. Those 2 egrets stayed within inches of the tractor as I cut.thought for sure I’d hit one eventually, but didn’t.
   / What did you do on or to your LS Tractor today? #643
When I mow the taller stuff I dont see pigs probably because if I did I would be adding them to the freezer lol instead I see a lot of rabbits and frogs some snakes lol of course I would eat those as well but they are always too little not seeing the big ones!
   / What did you do on or to your LS Tractor today? #645
What am I looking at in the "help" picture? I see the hog in the second one.
Yup, 1st has baby pig top left
2 nd has big hog and 2 egrets.
   / What did you do on or to your LS Tractor today? #646
Another few hours of field mowing with brush hog. Had to quit when the screen in front of radiator got full. Not sure how to remove, but air compressor with long wand did great.
   / What did you do on or to your LS Tractor today? #647
if you go to the other side. you will see a small thumb screw on the edge in the middle. unscrew it and slide the screen out. then do the reverse to put it in.
   / What did you do on or to your LS Tractor today? #648
Yup, saw it, tried it, FEL arm in way. Should be a split screen. Maybe next time I’ll lift FEL and try.
   / What did you do on or to your LS Tractor today? #649
Here's the best tool I've found to clean your radiator, A/C condenser, hydro cooler. I use mine on both tractors and our Kubota ZD1211 zero turn radiator. You get an air tool and a water tool. It's 5 stars!
The air tool also works great for blowing out air filters, from the inside.
https://www.amazon.com/Radiator-Genie-Cleaning-Efficiency-Radiators/dp/B01NAU8J6D
My LS Dealer gave me screws with the big plastic knobs for the shields on both sides of the radiator, so it's "tool free". I'll get a picture in the morning.
Pro Tip: Don't park your Tractor with left side high, when you want to pull the screen in front of your radiator. The front left tire blocks removing the screen. Level or right side high works best.
   / What did you do on or to your LS Tractor today? #650
David, raise your FEL up full height, so you don't hit your head walking under it. Access is way easier.
Don't forget to clean your air filter too.
2023 Load Trailer (A55787)
2023 Load Trailer...
2007 Ford F-750 2,000 Gallon Water Truck (A55973)
2007 Ford F-750...
TPM RM900SB All Terrain Remote Controlled Weed and Brush Mower (New/Unused) (A59225)
TPM RM900SB All...
2019 ALLMAND MAXI-POWER 25 GENERATOR (A58214)
2019 ALLMAND...
PITTSBURG 2R CULTIVATOR (A52708)
PITTSBURG 2R...
2017 Liebherr L566 X Power Wheel Loader, PIN# VATZ1484EZB044020, Liebherr Turbo Diesel Engine, Cr... (A59076)
2017 Liebherr L566...
