What did you do on or to your LS Tractor today?
   / What did you do on or to your LS Tractor today? #631
today went to dealer to pick up new box blade got a 8ft one was getting tired of using my old 5ft one now will be able to get areas level faster!
   / What did you do on or to your LS Tractor today? #632
5 to 8 is a big jump. Big results will follow.
   / What did you do on or to your LS Tractor today? #633
yes hope so lol im still looking for a pull type 4 to 6 adjustable grader it needs to be 10 to 12ft so i can get all my fields the way i want them its a lot of work but once i get the pond all set with fields draining to them it will increase growing area by about 20% its about a 2 year project lol
   / What did you do on or to your LS Tractor today? #634
Today I'm trying to get the light bars that arrived this week for my tractor put on and wired making temporary brackets today will weld up some better ones later but might be like some other temporary stuff I do that in 2 years when these fail I make better ones lol
Accomplished a hugely complicated task today. Installed the home brewed 3 point trailer mover and moved my log splitter about 50' across level ground. I have no idea how I could have done that without my mean blue machine.
   / What did you do on or to your LS Tractor today? #636
PICTURES!!!
   / What did you do on or to your LS Tractor today? #637
Yes sounds pretty dangerous good thing you had the tractor! Lol
   / What did you do on or to your LS Tractor today? #638
Not a major, but used my bucket for 1st time. Before I went on vacation, had to dig a trench and replace propane lines. Today, I backfilled at the propane tank. The hand work at end was harder than the FEL
Now I have the rotary cutter mounted and mowing some fields
Today’s start
   / What did you do on or to your LS Tractor today? #639
Had some a little extra help mowing
And extra supervision
   / What did you do on or to your LS Tractor today? #640
I just love all that supervision! Same happens here. Flickr
HEAVY DUTY TRANSMISSION JACK (A58214)
HEAVY DUTY...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A57024)
NEW HOLLAND 706 30...
2024 CATERPILLAR 930 AG HANDLER WHEEL LOADER (A52709)
2024 CATERPILLAR...
Kubota M108S (A53317)
55-Gallon Drum of Komatsu Hydraulic Oil HO 56-HE (UNOPENED) (A59076)
55-Gallon Drum of...
2007 Ammbusher DL66 Hydraulic 66in Brush Cutter Skid Steer Attachment (A55973)
2007 Ammbusher...
