Popular mythconceptions
   / Popular mythconceptions #42
Another one:
It is safer to pull hard with a chain than a strap or cable, because if it breaks, it will fall harmlessly to the ground instead of snapping back.
Bruce
   / Popular mythconceptions #43
I'm saying exactly the same. But the myth is that dismounting a cylinder, turning it around, and remounting it will cause the stronger and weaker forces to change direction.
I've heard this kind of statement many times, but it is wrong. "That's a nice dump trailer you made. But if you turned that cylinder around it would lift more."
Bruce
If it was a double acting cylinder, he could crush himself with force instead of gravity.
   / Popular mythconceptions #44
Obviously the cylinder would be stronger with the rod up because then it痴 not having to lift the weight of the body and fluid. Insert sarcasm here. The much more important thing to do is position the cylinder so the hoses aren稚 moving and chafing them.
Only thing that changes is the speed of movement as the rod end takes less fluid. Dare you to tell the difference w/o a stop watch.
Ron
   / Popular mythconceptions #45
Another one:
Bruce
Harmlessly to the ground not so much but I think chains do stretch less than the other 2. The best option is using one rated for the pull. And make sure the hooks are equal or greater than the device.
   / Popular mythconceptions #46
Ever see a cable brake under tension? Can easily cut a mans head off sitting on a tractor seat.
Ron
   / Popular mythconceptions #47
Ron
The extension and retraction speeds won't change if you flip a cylinder. No matter if it's rod end up or rod end down, the large end gets the fluid anytime you extend it and the rod end gets the fluid on retraction.
   / Popular mythconceptions #48
Another one:
Bruce
That is not a misconception, but is a matter of degree. cable is lethal! Chain? Ho Hmmm.
   / Popular mythconceptions #49
Is a 20 foot chain any less dangerous than a 20 foot cable? Of course a 200’ cable is deadly.
2017 FORD F250 SUPER DUTY EXT CAB SERVICE TRUCK (A55745)
2017 FORD F250...
Front End Loader Joystick and Pump Sprayer (A54865)
Front End Loader...
2020 CATERPILLAR 303.5E2 CR EXCAVATOR (A52706)
2020 CATERPILLAR...
Scag STT61V 61in Zero Turn Mower (A51694)
Scag STT61V 61in...
2014 Ag Spray Schaben Sidedresser (A53472)
2014 Ag Spray...
2014 Nissan Pathfinder SUV (A55853)
2014 Nissan...
