Popular mythconceptions
   / Popular mythconceptions #42
Another one:
It is safer to pull hard with a chain than a strap or cable, because if it breaks, it will fall harmlessly to the ground instead of snapping back.
Bruce
   / Popular mythconceptions #43
I'm saying exactly the same. But the myth is that dismounting a cylinder, turning it around, and remounting it will cause the stronger and weaker forces to change direction.
I've heard this kind of statement many times, but it is wrong. "That's a nice dump trailer you made. But if you turned that cylinder around it would lift more."
Bruce
If it was a double acting cylinder, he could crush himself with force instead of gravity.
   / Popular mythconceptions #44
Obviously the cylinder would be stronger with the rod up because then it痴 not having to lift the weight of the body and fluid. Insert sarcasm here. The much more important thing to do is position the cylinder so the hoses aren稚 moving and chafing them.
Only thing that changes is the speed of movement as the rod end takes less fluid. Dare you to tell the difference w/o a stop watch.
Ron
   / Popular mythconceptions #45
Another one:
Bruce
Harmlessly to the ground not so much but I think chains do stretch less than the other 2. The best option is using one rated for the pull. And make sure the hooks are equal or greater than the device.
   / Popular mythconceptions #46
Ever see a cable brake under tension? Can easily cut a mans head off sitting on a tractor seat.
Ron
   / Popular mythconceptions #47
Ron
The extension and retraction speeds won't change if you flip a cylinder. No matter if it's rod end up or rod end down, the large end gets the fluid anytime you extend it and the rod end gets the fluid on retraction.
   / Popular mythconceptions #48
Another one:
Bruce
That is not a misconception, but is a matter of degree. cable is lethal! Chain? Ho Hmmm.
   / Popular mythconceptions #49
Is a 20 foot chain any less dangerous than a 20 foot cable? Of course a 200’ cable is deadly.
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
STORAGE SHELTER KIT (A53843)
STORAGE SHELTER...
2006 FORD F-350 (A53422)
2006 FORD F-350...
Cat TH407C Telehandler (A53472)
Cat TH407C...
2022 BRAZ0 40FT PIT BOSS BELLY DUMP TRAILER (A56129)
2022 BRAZ0 40FT...
2012 Ram 5500 4x4 Dump Truck, VIN # 3C7WDNAL1CG223770 (A54865)
2012 Ram 5500 4x4...
