SSQA For Kubota - I need one.
   / SSQA For Kubota - I need one.
Boy I sure would like to see some pictures or video.
I've got everything loaded in the truck. After work today I'm going to weld up the quick attach. Brace and fishplate the **** outta it. Depending on what time I make it back to the Homestead, I'll try to remember to take a video of the plow setup.
I ran outside a few minutes early this morning to take a quick video of the plow setup.
Sorry for the quality. Its the best I could knock out before I had to leave for work.
Didn't bother taking video of the tractor side since a lot of it is in my truck. What sucks is I have to tack it in at the shop, drive back home, make sure it all fits, then drive back tomorrow, and weld it solid. Two days without riding the motorcycle in. :thumbdown:
   / SSQA For Kubota - I need one. #13
Two sections of square tube, sliding fit, pivots on each end, locking lever and nut on the outside bit. Tighten lock lever/bolt when you park it, loosen when in use. Permanently attached, won't misplace it, infinitely adjustable for position when parking.
I was just going to weld up a box for a piece of sched 40 to fit into. One on the plow side, one of the plate side. Toss the pipe on the plow side box, then the plate side, then lean the plate forward so it doesn't fall out. Once attached, curl the arms back relieving the pressure holding the pipe, then remove the pipe. Toss it aside in the mean time.
   / SSQA For Kubota - I need one. #16
I could not open, all got was a black box on my screen. This has happened with other guys posted picture or video. I don't know how to get them to open. But thanks for posting and going to the trouble to do so.
   / SSQA For Kubota - I need one. #17
Not my greatest welds. But I took it home and it lines up just fine on the tractor. Now to bring it back to the shop after work today and plate the whole thing.
   / SSQA For Kubota - I need one. #19
Maybe I missed something in the thread but my first though seeing those pics is......
Those flat braces have no torsion strength.
Those plates are not going to remain in sync like that.
You can see on the item Travis posted, WR long used box tube as it provides torsion strength.
Again, if that is not your finished product then disregard my comment. WRL-APUM-2T.jpg
   / SSQA For Kubota - I need one. #20
Kubota uses round tube.
2006 USH BOAT & 2012 TL (A56859)
2006 USH BOAT &...
1995 Freightliner FLD120 T/A Wet Kit Day Cab Truck Tractor (A55973)
1995 Freightliner...
5004 (A55851)
5004 (A55851)
2021 Caterpillar 308CR Midi Excavator (A55973)
2021 Caterpillar...
WhisperWatt DCA-85SSM 85kVA Towable Diesel Generator (A55973)
WhisperWatt...
John Deere 7230 131HP 4WD Agricultural Utility Tractor (A56857)
John Deere 7230...
