What did you do on or to your LS Tractor today?
   / What did you do on or to your LS Tractor today? #611
I do have the hammers and that is part of reason. My 1st flail was used as a ground engagement tool due to the extensive pig rootings and I used that first set of hammers to the point of almost ineffective on just grass. I also broke a fair number on the unearthed rocks. Never have sharpened them. I have also used the Y blades but less happy with cut, leaves a lot of stalks at times. Wear out quicker too.
   / What did you do on or to your LS Tractor today? #612
Here's what I got finished over the weekend. Been working at it as much as I can. between the Mississippi rain & heat then "the job". One pasture at a time. I don't have a spray rig yet. I'm gonna pick up a small one , even if I have to use a spray wand at first.
this is my Therapy
looking from the top
looking at the same pasture other side
   / What did you do on or to your LS Tractor today? #613
Well with a couple of 90 hour work weeks due to more severe weather, I havent put many hours on the MT125 lately. I'm putting a few on it tonight, but nothing exciting. 20190708_190731.jpeg
   / What did you do on or to your LS Tractor today? #614
With all the rain last night and today, 1.94 inches, I gave mine the day off.
   / What did you do on or to your LS Tractor today? #615
I'm not using tractor much today just have pallet on forks so it can be tabletop holds my chop saw making a new portable goat house will post photos when it finished using repurposed materials!
   / What did you do on or to your LS Tractor today? #616
And rain is slowing me down some lol
   / What did you do on or to your LS Tractor today? #617
this is my Therapy
What is the plan for fields after you get them all worked over?
   / What did you do on or to your LS Tractor today? #618
looking to put in a mixed hay, something I can rotate my goats through.
   / What did you do on or to your LS Tractor today? #619
You running goats?
what kind and how many?
   / What did you do on or to your LS Tractor today? #620
You running goats?
I have 6nubian dwarf does 6 Wetherspoon I plan to get a small dwarf buck then get to about 30 to 40 using to clear brush with controlled fencing the 12 can clear a area fenced in with 300ft of fence in a month I will use them for getting the fences on my 95 acres clean of brush so that I can replace the 5 strand barb perimeter fencing with 8 or 9 strand barb that way I can then have it almost goat ready I also have 65 acres of woodland and lots of mother in law vines that if not stopped will kill a lot of my trees they eat all the leaves off it pretty good!
BUSH HOG 14' ROTARY MOWER (A52708)
BUSH HOG 14'...
2025 Swict 66in Bucket Skid Steer Attachment (A56857)
2025 Swict 66in...
2020 POLARIS RANGER 1000 RTV (A52708)
2020 POLARIS...
40' x 20' All Metal Carport (New/Unused) (A59225)
40' x 20' All...
2006 Ford F-450 4x4 Service Truck (A56858)
2006 Ford F-450...
JRB 54" QUICK ATTACH HANG ON WHEEL LOADER FORKS (A52709)
JRB 54" QUICK...
