What did you do on or to your LS Tractor today?
   / What did you do on or to your LS Tractor today? #611
I do have the hammers and that is part of reason. My 1st flail was used as a ground engagement tool due to the extensive pig rootings and I used that first set of hammers to the point of almost ineffective on just grass. I also broke a fair number on the unearthed rocks. Never have sharpened them. I have also used the Y blades but less happy with cut, leaves a lot of stalks at times. Wear out quicker too.
   / What did you do on or to your LS Tractor today? #612
Here's what I got finished over the weekend. Been working at it as much as I can. between the Mississippi rain & heat then "the job". One pasture at a time. I don't have a spray rig yet. I'm gonna pick up a small one , even if I have to use a spray wand at first.
this is my Therapy
looking from the top
looking at the same pasture other side
   / What did you do on or to your LS Tractor today? #613
Well with a couple of 90 hour work weeks due to more severe weather, I havent put many hours on the MT125 lately. I'm putting a few on it tonight, but nothing exciting. 20190708_190731.jpeg
   / What did you do on or to your LS Tractor today? #614
With all the rain last night and today, 1.94 inches, I gave mine the day off.
   / What did you do on or to your LS Tractor today? #615
I'm not using tractor much today just have pallet on forks so it can be tabletop holds my chop saw making a new portable goat house will post photos when it finished using repurposed materials!
   / What did you do on or to your LS Tractor today? #616
And rain is slowing me down some lol
   / What did you do on or to your LS Tractor today? #617
this is my Therapy
What is the plan for fields after you get them all worked over?
   / What did you do on or to your LS Tractor today? #618
looking to put in a mixed hay, something I can rotate my goats through.
   / What did you do on or to your LS Tractor today? #619
You running goats?
what kind and how many?
   / What did you do on or to your LS Tractor today? #620
You running goats?
I have 6nubian dwarf does 6 Wetherspoon I plan to get a small dwarf buck then get to about 30 to 40 using to clear brush with controlled fencing the 12 can clear a area fenced in with 300ft of fence in a month I will use them for getting the fences on my 95 acres clean of brush so that I can replace the 5 strand barb perimeter fencing with 8 or 9 strand barb that way I can then have it almost goat ready I also have 65 acres of woodland and lots of mother in law vines that if not stopped will kill a lot of my trees they eat all the leaves off it pretty good!
FRONT WHEEL SPACERS (A52708)
FRONT WHEEL...
2007 Homemade Pipe Trailer (A55973)
2007 Homemade Pipe...
New/Unused CFG Industrial QK16R Mini Excavator (A57453)
New/Unused CFG...
2021 Ram ProMaster City Van (A56858)
2021 Ram ProMaster...
(4) CAMARO 5 LUG WHEELS & 245/50R16 97H TIRES (A54757)
(4) CAMARO 5 LUG...
2019 John Deere 310L EP Backhoe (A53485)
2019 John Deere...
