Concrete the easy way
/ Concrete the easy way #21
I use miracle grow instead of leveling powder. You neophytes make me laugh. lol
We make you laugh????? Who you think you BSing by saying a 6x6 slab will morf into a 20x20 if sprinkled with a little Miracle Grow. Now can we get back on task for the sake of those thinking about pouring a slab to park their tractor on?
/ Concrete the easy way #22
I'm thinking you may have missed the gist of this thread or perhaps your humor is drier than mine. Ok you got me.lol
/ Concrete the easy way #23
You all make me laugh, i've been using dehydrated concrete for years! Just add a little water and a little stirring and a little transporting and a little patting here and there....
/ Concrete the easy way #24
:yes:
/ Concrete the easy way #25
The idea sounds good, in a general sense, but I wouldn't do it.
Grass dies, pouring on the ground will allows the moisture to settle in the ground and let the concrete to harden too fast and too hard.
I'm no Concrete Contractor, IMHO, wire or re-rod is the only way to go.
I'm not saying this method won't work but for long term success with concrete, "Do It Right The First Time" !
/ Concrete the easy way #26
The type of grass you pour on makes for a big difference on how it performs when used for rebar. Tall stemmed grasses will outperform shorter types like Bluegrass. The tall white or yellow clovers ( five foot ) with their multi branched stems are the best for strengthening concrete especially if multi directional stresses must be covered.
/ Concrete the easy way #27
I have seen pictures of bamboo (a grass) used as reinforcement for concrete
/ Concrete the easy way #28
I don't know if oak is stronger than bamboo, I have some here, but not bamboo. Do you think oak branches would work as the reinforcement? I'd even be willing to cut a tree down to use as the concrete reinforcement. Do you think I should go with larger logs since they are stronger than the grasses?
/ Concrete the easy way #31
It would probably float too.
/ Concrete the easy way #33
I understand most underground mines are now using shotcrete infused with hemp fibers instead of steel. Keeps the men singing their happy songs apparently.
/ Concrete the easy way #34
OK so I finally got the drift here, this is BS !
I really thought it was something that people were doing !
Thanks for the ride ! Funny, LoL !
/ Concrete the easy way #37
Too much information!
Most folks can just go with the basics!
/ Concrete the easy way #40
Sherley you jest.
No Jest. It’s already happening with concrete paver blocks. Doing a little more investigating one will find quite a few moulded concrete items on the market. As always I’m just a little behind on what goes on!
(4) Yetter Trash Wheels and Cutter (A65640)
(4) Yetter Trash...
Landhonor Quick Attach Tree Puller (A66285)
Landhonor Quick...
Landhonor SAD-12-23C Skid Steer Mount Auger (A62679)
Landhonor...
2016 Ford F-350 Pickup Truck (A61568)
2016 Ford F-350...
Fire Ring (A65640)
Fire Ring (A65640)
Dexter trailer axles (A61567)
Dexter trailer...
