Pallets in fields
   / Pallets in fields #3,141
You know how they add water ballast to tractor tires, could you fill your bike inner tubes instead of balancing buckets? Would that take more trips though - if only I could remember the answer to that school maths paper -
If Jim's mountain bike has 26 inch wheels, each with a tube of internal diameter 59mm and he lives 5km from the beach, how many km must he ride to nuke 10 pallets at half a gallon per Triffid ? :confused2:
497.11 chains per hogshead.
   / Pallets in fields #3,142
Wheels are 29 inch and tyres are the wider mountain bike tyres so greater volume so might cut down one trip. But the tube is fitted with the French Presta valve which could be a pain in the posterior to get the water past.
   / Pallets in fields #3,143
The chain was a length measurement;
Surveyor's chain, also called Gunter's chain, measuring device and arbitrary measurement unit still widely used for surveying in English-speaking countries. Invented by the English mathematician Edmund Gunter in the early 17th century, Gunter's chain is exactly 22 yards (about 20 m) long and divided into 100 links.
The hogshead was a volume measurement that was extremely variable;
A tobacco hogshead was used in British and American colonial times to transport and store tobacco. It was a very large wooden barrel. A standardized hogshead measured 48 inches (1,219 mm) long and 30 inches (762 mm) in diameter at the head (at least 550 L or 121 imp gal or 145 US gal, depending on the width in the middle). Fully packed with tobacco, it weighed about 1,000 pounds (454 kg).
A hogshead contains about 300 L (66 imp gal; 79 US gal).[1]
The Oxford English Dictionary (OED) notes that the hogshead was first standardized by an act of Parliament in 1423, though the standards continued to vary by locality and content. For example, the OED cites an 1897 edition of Whitaker's Almanack, which specified the number of gallons of wine in a hogshead varying by type of wine: claret (presumably) 46 imperial gallons (55 US gal; 209 L), port 57 imperial gallons (68 US gal; 259 L), sherry 54 imperial gallons (65 US gal; 245 L); and Madeira 46 imperial gallons (55 US gal; 209 L). The American Heritage Dictionary claims that a hogshead can consist of anything from (presumably) 62.5 to 140 US gallons (52 to 117 imp gal; 237 to 530 L).
Eventually, a hogshead of wine came to be 63 US gallons (52.5 imp gal; 238.5 L), while a hogshead of beer or ale is 64 gallons (250 L if old beer/ale gallons, 245 L if imperial).
A hogshead was also used as unit of measurement for sugar in Louisiana for most of the 19th century. Plantations were listed in sugar schedules as having produced x number of hogsheads of sugar or molasses. A hogshead was also used for the measurement of herring fished for sardines in Blacks Harbour, New Brunswick.
So;
497.11 x 22= 10,936.42 yards or 131,237.04 ft or 24.8555 US miles.
1 hogshead = 79 US gallons so 3.178 gallons per mile
:drink:
   / Pallets in fields #3,144
Just curious....
Are these tires - hogsheads on pallets?
   / Pallets in fields #3,145
Jim, everyone knows the correct spelling of tyres is tires. We await you getting with the program.
   / Pallets in fields #3,149
And here I was thinking the answer to everything was 42...:confused3:
42 is the answer to the ultimate question of life, the universe and everything.
   / Pallets in fields #3,151
My wood piles seem to have some kind of grid like growths under them that seem to be sending out orange tentacles.
Not sure what kind of -icide I need. Or maybe an ectoplasm ray burst
   / Pallets in fields #3,152
T
A hogshead contains about 300 L (66 imp gal; 79 US gal).[1]:drink:
Even with the battery fully charged I don't think I could manage that much volume loose on the bike.
There is English English: American English: and Australasian English. Tire is in the Ozzie/Kiwi version of the language and has a lot more colourful words.
   / Pallets in fields #3,153
How am I going to carry 300 litres, unwrapped on this ?
   / Pallets in fields #3,157
Tow a furphy behind it.
That'll send everybody to Wikipedia :)
The water will have to be unwrapped coz the g/ment, in their wisdom, (shows how thick they are) has banned the use of single use plastic bags.
This water will be single use.....I'm not taking it back
   / Pallets in fields #3,158
Just the first part got me to check . . . :)
   / Pallets in fields #3,159
It'll take up a lot less space if you dehydrate it first. I still have a couple cases from 2000 in storage.
2021 Billy Goat F902H Walk-Behind Debris Blower (A59228)
2021 Billy Goat...
2016 INTERNATIONAL PROSTAR TANDEM AXLE DAY CAB (A59904)
2016 INTERNATIONAL...
2021 VERMEER S925TX STAND ON SKIDSTEER (A52709)
2021 VERMEER...
S/A Fuel Tank Trailer (A59231)
S/A Fuel Tank...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
