Kubota LA211 - hydraulic oil leak from Loader control block
   / Kubota LA211 - hydraulic oil leak from Loader control block #1
Dover7838
Kubota bx2200
Have a 02 BX 2200. Bought used last fall. Has LA211 loader. Noticed small puddle of hydraulic oil. Appears the be coming from the loader control block on the side of the control valve.
Before I order a bunch of replacement parts, since nothing appears cracked or broken, can I pull the fittings, and apply some kind of 菟lumbers putty or thread tape? Seems to be coming from thread area. Appears some kind of thread putty on there already?
Thanks in advance.
   / Kubota LA211 - hydraulic oil leak from Loader control block #2
I use Teflon tape.
It's likely that they worked themselves loose.
Thank you for the fast reply. I’ll give that a shot tomorrow
   / Kubota LA211 - hydraulic oil leak from Loader control block #4
Teflon tape and hydraulic valves are not a good combination. I use locktite 545 thread sealant. It will seal pipe threads and keep them from coming loose.
   / Kubota LA211 - hydraulic oil leak from Loader control block #5
Good to know.
I grew up folks telling me to use Teflon tape on hydraulics.
Personally, I never had an issue using it, and it's on my LA211.
After reading some info about Teflon tape and hydraulics, nope... no way will I ever use it again!
I dropped some Locktite 545 in my Amazon basket for my next order...
Thanks for the tip!
   / Kubota LA211 - hydraulic oil leak from Loader control block #6
You did try tightening them all up correct? I have found a few loose on mine. Just to confirm this is the reason for the leak.
   / Kubota LA211 - hydraulic oil leak from Loader control block #7
They likely just need to be tightened a bit. Mine leaked and a small twist fixed it with no added drama. Common problem.
2016 John Deere 5055E 55HP Utility Tractor (A55973)
2016 John Deere...
More info coming soon! (A56859)
More info coming...
2020 Deere 750K LGP (A53317)
2020 Deere 750K...
2015 DRAGON 130 BBL STEEL VACUUM TRAILER (A58214)
2015 DRAGON 130...
TEST YOUR BID BUTTON! (A58375)
TEST YOUR BID...
Bucket (A55973)
Bucket (A55973)
