front bucket dropping overnight
/ front bucket dropping overnight #101
A directional control valve leaking internally won’t be repaired by replacing seals. The spools meter and control flow by sealing directly against the valve body. Some internal leakage is necessary because the parts have clearances so the spool will move in its bore. Excessive leakage will require that hard parts be replaced. Replacing a spool won’t fix wear or a flaw in the valve body.
/ front bucket dropping overnight #102
As per the original question; it's thermaldyamics at work. Once the pressure created by the pump is removed from the equation your hydro oil will "relax"contrary to the illusion that our implement might remain elevated without any system leaks. Maintaining the bucket at height fighting gravity should imply that you've created an authentic perpetual motion machine. Cheers!
/ front bucket dropping overnight #103
Seals in a valve don't help? I rebuilt the control valve on my John Deere Backhoe front bucket. The seal kit was expensive but it greatly reduced the bucket drop to almost none.
/ front bucket dropping overnight #104
Lockport,
I am not sure I understand your point and how you call this thermodynamic. The pump pressure creates movement, it does not hold the load. As long as the cylinder is not at either extreme, The pressure in the cylinder should be the same whether the pump is in the loop or not. The pressure in the cylinder is proportional to the load it must support. If the load is constant and the pressure increases, the load would raise to equalize pressure again. I am also lost on the perpetual motion reference. The goal is to create a static system, not dynamic.
/ front bucket dropping overnight #105
The only seals I have ever seen in a valve are the o-rings or quad-rings that seal the spools to the casting. That isolates the tank-port passages from atmosphere, and prevents the valve from leaking externally. But does NOTHING to seal the tank port from the work ports. There are NO SEALS for that. As RickB said, Spools seal direct to the casting. Metal on metal. With tolerances in the 0.0001" range. So NO, a bucket leaking down will NOT be solved with simply changing case seals in the valve casting
/ front bucket dropping overnight #106
Safest answer ...... don't leave the bucket raised. Put everything on the ground before you leave the machine.
207923 (A63290)
207923 (A63290)
2025 Hydraulic Plate Grapple Mini Skid Steer Attachment (A61572)
2025 Hydraulic...
2012 Can-Am Spyder Motorcycle (A61574)
2012 Can-Am Spyder...
Bobcat 873 (A55272)
Bobcat 873 (A55272)
2023 John Deere 333G Track Loader (A63111)
2023 John Deere...
CATERPILLAR D8T CRAWLER DOZER (A65053)
CATERPILLAR D8T...
