What does this mean?
/ What does this mean? #1
aspg4
texarkana, ar
Massey Fergerson 135, TYM 554
Anyone know what these symbols mean on my dash monitor. SPN:0 and under it FM1:0 The symbols flash on and off..
/ What does this mean? #2
Your display is showing you have a active fault code. SPN stands for Suspect Parameter Number and FMI stands for Failure Mode Identifer. Usually after the SPN you will have a three or four digit number and after the FMI it will be a one or two digit number. Once you have the numbers you could call your dealer and he can tell you what the fault is. Hope this helped.
Thank you very much. The display on both show 0. The original display went bad, and it was replaced by a new one. It has been showing these symbols ever since the new display was installed. Maybe something was not plugged in correctly..
/ What does this mean? #4
Either what you say aspg4 or a portion of the software has not be calibrated with the new display. Call the dealer.
2016 New Holland Boomer 47 4WD 45HP Loader Utility Tractor with Bush Hog BH16-2 Brush Cutter (A64553)
2016 New Holland...
MACH Rescue Tools with Power Unit (A64553)
MACH Rescue Tools...
2020 INTERNATIONAL MV607 4X2 S/A 26FT NON CDL BOX TRUCK (A67148)
2020 INTERNATIONAL...
2015 Chevrolet Tahoe SUV (A64557)
2015 Chevrolet...
2017 Ford Explorer AWD SUV (A64557)
2017 Ford Explorer...
2022 CATERPILLAR 289D3 SKID STEER (A65053)
2022 CATERPILLAR...
