GX 3025 pto question
/ GX 3025 pto question #1
double hunter
Gold Member
Ford 1715
New to me GX 3025, 2016, 65 hrs,,just bought it today,,everything seems ok to me,,,my only concern is it seems like the pto us not running quietly,,never had an LS before,,may be normal,,also the pto shaft does not turn when it is turned offr,,this may also be normal,,the owner could not find the manuals today but is looking for them .any help appreciated,, theres a dealer not to far from here,,may ride by there tomorrow,,any thoughts appreciated
/ GX 3025 pto question #2
well I went to the link I had saved for LS to share the link for the owners manual, and it's no longer there. apparently they've stopped making the xg line and have replaced with the MT line.
I do have the owners manual in PDF form saved on my computer, if I could figure out how to share it with you I would be happy to. In the mean time, I'm going to keep looking to see if I can find it online, that's ridiculous that they don't still make that available online somewhere
Thanks,, got it book marked,,I appreciate the info
Just a little fyi,,went by the dealership and the pto output shaft does not "freewheel" according to the folks there,,its made to quit spinning when its turned off,,this tractor has been sitting up for a while and he said to run the stew out it, could have a little corrosion built up in the drive train,,its also got a couple years warranty left and if it breaks they will fix it,,I bush hogged with it a little this morning and it all works ok,,we'll see
/ GX 3025 pto question #6
wow, I should have told you that. That's one of the things with the electric PTO. Can be a good thing, or if you're trying to line up a PTO shaft, can be a bad thing, LOL
if it's been sitting that long without being run, I would personally change all the fluids and filters before I ran it much. Condensation will form on the inside and mix the moisture with the oil
2021 Ford F-150 4x4 Crew Cab Pickup Truck (A64556)
2021 Ford F-150...
2013 Ford F-150 Pickup Truck (A64194)
2013 Ford F-150...
Heavy Duty Pipe (A62679)
Heavy Duty Pipe...
2006 Ford F-750 Terex Commander C1017 Digger Derrick Truck (A64194)
2006 Ford F-750...
KL480 Ventrac tiller
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
