JD 855 Turbo Project.....need to up the fuel
   / JD 855 Turbo Project.....need to up the fuel #11
Diesels are not like a gas engine where a perfect air fuel ratio does exist, but you can over fuel a diesel and burn pistons, valves etc. With a stock injection pump and injectors that would be hard to do but on a common rail when an injector sticks open or over fuels, bad things happen.
Thanks for the info!
I see your point
   / JD 855 Turbo Project.....need to up the fuel #13
Back the dam thing out till it starts smoking heavy & screw it back in a smidge.. DONE.
That is kind of my plan!
Working on the intake and exhaust plumbing.
Will post pics of the finished product.
   / JD 855 Turbo Project.....need to up the fuel #15
Yes, please follow thru with the project updates. I'm a fan of all things diesel, and have turbo'd NA ones myself, and dream of doing that to my lil JD 3005 someday... so please, pictures and tech details, parts info, the more detail the better! I'll folliw along and offer any advice or opinions I may have, as well as ask questions.
So far 4.5 psi full power with the fuel up.
I would like more boost so I ordered a GT-12 which should be "almost" a straight bolt on.
The GT-15 just starts in about the time I run out of rpm. Just too big.
The GT12 should work better.
Will post picts once I get it installed.
   / JD 855 Turbo Project.....need to up the fuel #17
Hello all, I just found the site after putting a turbo on my 955. I used a aftermarket RHB31 turbo. All the parts to install the turbo i found on jd parts. I am far more concerned with exhaust gas temperatures than boost. If you dont watch egt's you can get in trouble real quick by turning up the fuel to much.
   / JD 855 Turbo Project.....need to up the fuel #18
I have turbo'd my 955 using a aftermarket RHB31 turbo. If you havent already i I strongly suggest a exhaust temp gauge. You need to watch the exhaust temp when turning up the fuel. You would not believe how quickly things can get extremely hot with just a little added fuel
How'd you like the results?....how much boost are you producing?
   / JD 855 Turbo Project.....need to up the fuel #20
The tractor runs great. I recently used a 5 foot rototiller at full depth in sod ground and the engine never knew it was hooked to it . Egt's hung around 900ーf to 950ーf. I do not have a boost gauge .
2019 Ford Explorer (A55788)
2019 Ford Explorer...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A57024)
NEW HOLLAND 706 30...
2008 Chevrolet 1500 Silverado 4x4 Crew Cab Pickup Truck (A55852)
2008 Chevrolet...
UNUSED WOLVERINE MAD-12-12D HYD AUGER DRIVE & BIT (A57193)
UNUSED WOLVERINE...
UNUSED PROFESSIONAL X2600A ELECTRIC CONCRETE MIXER (A57193)
UNUSED...
