Backhoe BH77 going Up but not Down
/ BH77 going Up but not Down #1
Madison, Virginia
Kubota L3200 HST
All hydraulic controls work fine except the arm stick down as I知 trying to mount the BH77 to the tractor and need to raise it up to put the top pins in. I can bring the boom up, and then when I try down, pressure is released and it goes down but not enough pressure to extend the boom arm down. I removed hydraulic line to cylinder and in one direction, hydraulic fluid sprays out very good when I operate the up control, but when I operate the down it痴 definitely less of a flow, but there is flow. Any suggestions?
/ BH77 going Up but not Down #2
Are you sure you have the hoses connected in the correct pattern?
Yep. I figured it out. The valve control needed to be cleaned and the relief adjustment screw needed to be adjusted as well. All works well now. Was flying blind but the removal of the relief valve was pretty easy. I won稚 say as much for the tight cramped space I had to work in to get them out. Stupid Kubota engineers. What do they think of when designing these thing. I guess they think they will never need to be worked on.
/ BH77 going Up but not Down #4
What exactly did you do?
UNUSED WOLVERINE BUCKET (A64281)
UNUSED WOLVERINE...
2017 Nissan Altima 4 door (A63689)
2017 Nissan Altima...
Hitachi ZX75US Midi Excavator (A61572)
Hitachi ZX75US...
2012 Isuzu NPR HD w 5.2L 4HK1-TC Turbo Diesel (A63689)
2012 Isuzu NPR HD...
2025 Wolverine MSG-11-44W 44in Stump Grapple Mini Skid Steer Attachment (A61572)
2025 Wolverine...
2014 Ford F-550 Altec AT40M 40ft Material Handling Bucket Truck (A61568)
2014 Ford F-550...
